Libre NMS Specific Storage Display
Hi Pro’s,
Is there anyway that the storage graph will only show the device storage space or root directory space and not sub directories?
Hi @nix
The storage graph is only showing whatever your file system structure has, according to whatever the SNMP daemon is sending. If you have multiple partitions mounted (and sometimes multiple times in your case) then your system will report these to LibreNMS, which will then display them by default.
You can have a look in the link below, in order to create filters:
https://docs.librenms.org/Support/Configuration/#storage-configuration
Bye
