When I check the version I can see that its set to 22.9.0 and the database scheme version is set to 2022_09_03_091314_update_ports_adsl_table_with_defaults (246)
When you run ./daily.sh have you checked the log file for anything of relevance? Pretty odd i’ve not had an issue as each time i run it manually it updates the version.
I will see if I can check the log file. Out of curiosity, where are you checking to see if the update ran successfully? I just want to make sure I am looking in the correct place.
If the update ran successfully then you’re LibreNMS version (as of right now) should be version ‘24.5.0’. If it’s not then it wasn’t successful in some kind of way
run ./daily.sh and then check the log file afterwards. Also check your ./validate for issues that could be stopping the update.
