In the process of demo’ing Libre, and we’re currently really enjoying it - trying to tack on Smokeping but hit an issue
Currently having an issue with getting smokeping data to appear in the device tab - tab itself is appearing but not populating with graph data.
Followed the docs at Smokeping - LibreNMS Docs - so far so good
Everything working correctly on the smokeping gui directly at http://librenms01.xxx.ac.uk/smokeping/
But underneath the ping tab…
Nothing appearing.
Hopefully i’ve just overlooked something stupid… configs below, any help much appreciated!
/etc/nginx/conf.d/librenms.conf
server {
listen 80;
server_name librenms01.xxx.ac.uk;
root /opt/librenms/html;
index index.php;
charset utf-8;
gzip on;
location / {
location /api/v0 {
try_files $uri $uri/ /api_v0.php?$query_string;
location ~ \.php {
include fastcgi.conf;
fastcgi_split_path_info ^(.+\.php)(/.+)$;
fastcgi_pass unix:/var/run/php/php7.2-fpm.sock;
location ~ /\.ht {
deny all;
#Browsing to `http://librenms.xxx/smokeping/` should bring up the smokeping web interface
location = /smokeping/ {
fastcgi_intercept_errors on;
fastcgi_param SCRIPT_FILENAME /usr/lib/cgi-bin/smokeping.cgi;
fastcgi_param QUERY_STRING $query_string;
fastcgi_param REQUEST_METHOD $request_method;
fastcgi_param CONTENT_TYPE $content_type;
fastcgi_param CONTENT_LENGTH $content_length;
fastcgi_param REQUEST_URI $request_uri;
fastcgi_param DOCUMENT_URI $document_uri;
fastcgi_param DOCUMENT_ROOT $document_root;
fastcgi_param SERVER_PROTOCOL $server_protocol;
fastcgi_param GATEWAY_INTERFACE CGI/1.1;
fastcgi_param SERVER_SOFTWARE nginx/$nginx_version;
fastcgi_param REMOTE_ADDR $remote_addr;
fastcgi_param REMOTE_PORT $remote_port;
fastcgi_param SERVER_ADDR $server_addr;
fastcgi_param SERVER_PORT $server_port;
fastcgi_param SERVER_NAME $server_name;
fastcgi_param HTTPS $https if_not_empty;
fastcgi_pass unix:/var/run/fcgiwrap.socket;
location ^~ /smokeping/ {
alias /usr/share/smokeping/www/;
index smokeping.cgi;
gzip off;
/etc/smokeping/config.d/General
*** General ***
owner = LibreNMS Admin
contact = [email protected]
mailhost = my.mail.host
# NOTE: do not put the Image Cache below cgi-bin
# since all files under cgi-bin will be executed ... this is not
# good for images.
cgiurl = http://librenms01.xxx.ac.uk/smokeping.cgi
# specify this to get syslog logging
syslogfacility = local0
# each probe is now run in its own process
# disable this to revert to the old behaviour
# concurrentprobes = no
@include /etc/smokeping/config.d/pathnames
/opt/librenms/config.php
######Smokeping Config
$config['smokeping']['dir'] = '/var/lib/smokeping'; // Ubuntu 16.04 and newer Location
#$config['smokeping']['dir'] = '/opt/smokeping/data';
$config['smokeping']['pings'] = 20; // should be equal to "pings" in your smokeping config
$config['smokeping']['integration'] = true;
@include /etc/smokeping/config.d/General
@include /etc/smokeping/config.d/Alerts
@include /etc/smokeping/config.d/Database
@include /etc/smokeping/config.d/Presentation
@include /etc/smokeping/config.d/Probes
@include /etc/smokeping/config.d/Slaves
@include /etc/smokeping/config.d/Targets
@include /etc/smokeping/config.d/librenms.conf
