[root@v30svlnms01 librenms]# ./validate.php
Component | Version |
LibreNMS | 1.58.1-13-g0f3c6ba |
DB Schema | 2019_10_03_211702_serialize_config (147) |
PHP | 7.3.12 |
MySQL | 5.5.64-MariaDB |
RRDTool | 1.4.8 |
SNMP | NET-SNMP 5.7.2 |
[OK] Composer Version: 1.9.1
I have LibreNMS installed on a VM and have Oxidized installed on a separate VM. I am using NGINX for both as the web server. When LibreNMS is configured with HTTP/HTTPS and Oxidized is configured with just HTTP everything work fine.
When I configure HTTPS on Oxidized, I lose the ability to view configurations. If I open up a separate web browser tab and put in the oxidized https address, the page comes up fine, but when LibreNMS tries to connect to it, it does not connect.
The SSL certificates for LibreNMS and Oxidized share the same private key but have different certs.
LibreNMS nginx.conf
# For more information on configuration, see:
# * Official English Documentation: http://nginx.org/en/docs/
# * Official Russian Documentation: http://nginx.org/ru/docs/
user nginx;
worker_processes auto;
error_log /var/log/nginx/error.log;
pid /run/nginx.pid;
# Load dynamic modules. See /usr/share/doc/nginx/README.dynamic.
include /usr/share/nginx/modules/*.conf;
events {
worker_connections 1024;
http {
log_format main '$remote_addr - $remote_user [$time_local] "$request" '
'$status $body_bytes_sent "$http_referer" '
'"$http_user_agent" "$http_x_forwarded_for"';
access_log /var/log/nginx/access.log main;
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
include /etc/nginx/mime.types;
default_type application/octet-stream;
# Load modular configuration files from the /etc/nginx/conf.d directory.
# See http://nginx.org/en/docs/ngx_core_module.html#include
# for more information.
include /etc/nginx/conf.d/*.conf;
# server {
# listen 80 default_server;
# listen [::]:80 default_server;
# server_name _;
# root /usr/share/nginx/html;
# # Load configuration files for the default server block.
# include /etc/nginx/default.d/*.conf;
# location / {
# error_page 404 /404.html;
# location = /40x.html {
# error_page 500 502 503 504 /50x.html;
# location = /50x.html {
# Settings for a TLS enabled server.
server {
listen 443 ssl http2 default_server;
listen [::]:443 ssl http2 default_server;
server_name librenmsSRV.org
access_log /var/log/nginx/access_log;
ssl_certificate "/etc/pki/nginx/nginx-selfsigned.crt";
ssl_certificate_key "/etc/pki/nginx/private/nginx-selfsigned.key";
ssl_dhparam "/etc/pki/nginx/dhparam.pem";
ssl_session_cache shared:SSL:1m;
ssl_session_timeout 10m;
ssl_ciphers "EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH";
#ssl_ciphers HIGH:!aNULL:!MD5;
ssl_prefer_server_ciphers on;
ssl_verify_client off;
location / {
Oxidized nginx.conf
user nginx;
pid /run/nginx.pid;
events {
http {
sendfile on;
tcp_nopush on;
tcp_nodelay on;
server {
server_name _;
# work around till https can be configured
# secures http access from only the librenms vm
allow maskedIPaddress;
deny all;
# auth_basic "Restricted Access";
# auth_basic_user_file /etc/nginx/.htpasswd;
location / {
proxy_pass http://127.0.0.1:8888/;
server {
server_name anotherOxidizedSRV.org;
#access_log /var/log/nginx/access_log;
# SSL Config
ssl_certificate "/etc/pki/nginx/oxidzed.cer";
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
allow 10.10.107.15;
deny all;
location / {
Can anyone please help me get LibreNMS to work with Oxidized being HTTPS and on a separate VM?
