LibreNMS API: Device-Specific Endpoint "port_id" is Missing
When using the LibreNMS API to retrieve information about specific device ports, there seems to be an inconsistency in the returned data. The device-specific API does not return the port_id attribute for ports, while the general ports API does.
Issue Details:
  1. Device Specific API:
    • Endpoint: /api/v0/devices/DEVICE_ID/ports
    • Sample Output:
          "status": "ok",
          "ports": [
                  "ifName": "InLoopBack0"
    • The above output does not include the port_id attribute for the ports.
  2. General Ports API:
    • Endpoint: /api/v0/ports
    • Sample Output:
          "status": "ok",
          "ports": [
                  "port_id": 1,
    • This output includes the port_id attribute, which is missing from the device-specific API.
You can specify the columns you want returned in the API results for /api/v0/devices/DEVICE_ID/ports?columns=port_id,ifName
It’s in the docs
Thanks It helps.
