When using the LibreNMS API to retrieve information about specific device ports, there seems to be an inconsistency in the returned data. The device-specific API does not return the port_id attribute for ports, while the general ports API does.
Issue Details:
Device Specific API:
- Endpoint:
/api/v0/devices/DEVICE_ID/ports - Sample Output:
{ "status": "ok", "ports": [ { "ifName": "InLoopBack0" }, ... ] } - The above output does not include the
port_idattribute for the ports.
- Endpoint:
General Ports API:
- Endpoint:
/api/v0/ports - Sample Output:
{ "status": "ok", "ports": [ { "port_id": 1, "ifName": "InLoopBack0" }, ... ] } - This output includes the
port_idattribute, which is missing from the device-specific API.
- Endpoint:
