Hi All,
I am going to build a LibreNMS Central Server (WEB + DB) on Azure VM. It will have 3-4 distributed pollers at remote sites which will monitor in total 1000 devices (8000-10000 ports) via VPN.
For the LibreNMS Central Server VM on Azure, can you please give me an advice?
- how many vCPU?
- size of RAM?
- Size of SSD Storage?
Thank you
As you are going to have remote pollers, they are going to do the hard work.
For the main server (WEB+DB+RRD) I’ll say start with 8cpu 8gb.
About the SSD storage…Its hard to tell. It will depend on how many sensors/ports/etc each device have.
To have something to work with this is my install:
6,8G /opt/librenms/rrd/
11G /var/lib/mysql/
For the database, I have more than 6M rows in syslog. Thats why its so big.
