I understood that Prometheus support is alpha at best. Therefore, I would much appreciate if you could recommend
how to verify if the data stored within rrd are sent to Prometheus and recorded in Prometheus – any curl commands?
how to debug the root cause if the data are not sent to Prometheus – any debugging command on librenms to send the data?
Thanks very much in advance.
LibreNMS support for Prometheus was introduced by 1.39 Release.
LibreNMS + Prometheus env has been successfully set up on a Kubernetes cluster in our lab with jarischaefer/docker-librenms:1.45 prom/pushgateway:v0.5.2 prom/prometheus:v2.4.3
You can open Pushgateway frontend to see all the metrics received from LibreNMS.
Launch the ./poller.php or ./discovery.php with -d flag. If Prometheus storage is enabled, you will see notes and records about sending the data.
./poller.php
./discovery.php
Thanks very much @angryp!
