LibreNMS Docker is not receiving traps but the MacOS is able to recieve the traps. I already tried following the document https://docs.librenms.org/Extensions/SNMP-Trap-Handler/ Question: Is there a configuration Im missing or is there a way to debug it?
Reply for more information and try to give steps on what information you want (I quite new to SNMP traps)
Btw the Container is alpine linux
Docker Compose File:
services:
db:
image: mariadb:10
container_name: librenms_db
command:
- "mysqld"
- "--innodb-file-per-table=1"
- "--lower-case-table-names=1"
- "--character-set-server=utf8mb4"
- "--collation-server=utf8mb4_unicode_ci"
volumes:
- "./db:/var/lib/mysql"
environment:
- "TZ=${TZ}"
- "MARIADB_RANDOM_ROOT_PASSWORD=yes"
- "MYSQL_DATABASE=${MYSQL_DATABASE}"
- "MYSQL_USER=${MYSQL_USER}"
- "MYSQL_PASSWORD=${MYSQL_PASSWORD}"
restart: always
redis:
image: redis:7.2-alpine
container_name: librenms_redis
environment:
- "TZ=${TZ}"
restart: always
msmtpd:
image: crazymax/msmtpd:latest
container_name: librenms_msmtpd
env_file:
- "./msmtpd.env"
restart: always
librenms:
image: librenms/librenms:latest
hostname: librenms
cap_add:
- NET_ADMIN
- NET_RAW
ports:
- "8000:8000"
depends_on:
- db
- redis
- msmtpd
volumes:
- "./librenms:/data"
env_file:
- "./librenms.env"
environment:
- "TZ=${TZ}"
- "PUID=${PUID}"
- "PGID=${PGID}"
- "DB_HOST=db"
- "DB_NAME=${MYSQL_DATABASE}"
- "DB_USER=${MYSQL_USER}"
- "DB_PASSWORD=${MYSQL_PASSWORD}"
- "DB_TIMEOUT=60"
restart: always
dispatcher:
container_name: librenms_dispatcher
hostname: librenms-dispatcher
cap_add:
- NET_ADMIN
- NET_RAW
depends_on:
- librenms
- redis
volumes:
env_file:
- "./librenms.env"
environment:
- "TZ=${TZ}"
- "PUID=${PUID}"
- "PGID=${PGID}"
- "DB_HOST=db"
- "DB_TIMEOUT=60"
- "DISPATCHER_NODE_ID=dispatcher1"
- "SIDECAR_DISPATCHER=1"
restart: always
syslogng:
container_name: librenms_syslogng
hostname: librenms-syslogng
cap_add:
- NET_ADMIN
- NET_RAW
depends_on:
- librenms
- redis
ports:
- target: 514
published: 514
protocol: tcp
- target: 514
published: 514
protocol: udp
volumes:
env_file:
- "./librenms.env"
environment:
- "TZ=${TZ}"
- "PUID=${PUID}"
- "PGID=${PGID}"
- "DB_HOST=db"
- "DB_TIMEOUT=60"
- "SIDECAR_SYSLOGNG=1"
restart: always
snmptrapd:
container_name: librenms_snmptrapd
hostname: librenms-snmptrapd
cap_add:
- NET_ADMIN
- NET_RAW
depends_on:
- librenms
- redis
ports:
- target: 162
published: 162
protocol: tcp
- target: 162
published: 162
protocol: udp
volumes:
- ./mibs:/opt/librenms/mibs
env_file:
- "./librenms.env"
environment:
- "TZ=${TZ}"
- "PUID=${PUID}"
- "PGID=${PGID}"
- "DB_HOST=db"
- "DB_TIMEOUT=60"
- "SIDECAR_SNMPTRAPD=1"
- "SNMP_EXTRA_MIB_DIRS=/opt/librenms/mibs/transcelestial"
restart: always
@murrant is there any suggestions?
Update now my docker that is running snmptrapd which is different from my librenms container is receiving traps but my traps are not showing on the librenms web ui
