thanks for the info. But It looks like I need to stop and start the snmpd deamon in the container. How do I do that? It looks like the it’s not running as systemctl service.
#> podman exec librenms net-snmp-create-v3-user -ro -a 'snmp_password' -x 'snmp_privpass' -X AES snmp_user
Apparently at least one snmpd demon is already running.
You must stop them in order to use this command.
#> podman exec librenms systemctl stop snmpd
Error: exec failed: container_linux.go:380: starting container process caused: exec: "systemctl": executable file not found in $PATH: OCI runtime attempted to invoke a command that was not found
I tried also /usr/bin/systemctl but that didn’t work either.
