LibreNMS DOCS: missing script "os-updates.sh"
I’m trying to set up checks for updates according to
http://docs.librenms.org/Extensions/Applications/#os-updates
SNMP Extend
1.Copy the shell script to the desired host (the host must be added to LibreNMS devices)
2.Make the script executable (chmod +x /etc/snmp/os-updates.sh)
What must be included in script os-updates.sh?
Thank you
Mirino
You download it: https://github.com/librenms/librenms-agent/tree/master/snmp
Super!. Thx :wink:
It would be a good edit documentation as a step in the Apache section
http://docs.librenms.org/Extensions/Applications/#apache
SNMP Extend
  1. Download the script onto the desired host (the host must be added to LibreNMS devices)
    wget https://github.com/librenms/librenms-agent/tree/master/snmp
You can update the docs :slight_smile:
Docs updated.
helpful link:
