Hi Team,
We have planned for Gelera cluster configuration for Librenms
Server 1: Librenms Web and poller
Server 2, server 3 and server 4 : 3 nodes Gelera cluster configiration
Post DB cluster configurations, Poller stop working. kindly some one assist on this issue. If any sync missed out as part of Custer configurations
Please find below ./validate.php output
[librenms@adsomnossapp01 ~]$ ./validate.php
| LibreNMS | 24.8.0-21-g61ad4bfbb (2024-08-26T17:45:12+00:00) |
| DB Schema | 2024_08_12_232009_ent_physical_table_rev_length (298) |
| PHP | 8.1.28 |
| Python | 3.6.8 |
| Database | MariaDB 10.3.39-MariaDB |
| RRDTool | 1.7.0 |
| SNMP | 5.8 |
[OK] Composer Version: 2.7.9
[FAIL] APP_KEY does not match key used to encrypt data. APP_KEY must be the sam e on all nodes.
If you rotated APP_KEY, run lnms key:rotate to resolve.
[FAIL] Poller is not running. No poller has run within the last 300 seconds.
[WARN] Your install is over 24 hours out of date, last update: Mon, 26 Aug 2024 17:45:12 +0000
Modified Files:
config/database.php
html/.htaccess
html/ajax_dash.php
html/ajax_form.php
html/ajax_list.php
html/ajax_listports.php
html/ajax_ossuggest.php
html/ajax_output.php
html/ajax_table.php
html/api_v0.php
html/bandwidth-graph.php
html/billing-graph.php
html/calendar.jpg
html/css/L.Control.Locate.min.css
html/css/L.Control.Locate.min.css.map
and 812 more…
