Hi Lads,
some can help me please, i do restart centos but after restart was something wrong because service Librenms don’t work properly.
my service show “Whoops, looks like something went wrong.”
below is log from validate.php
fatal: ambiguous argument ‘HEAD’: unknown revision or path not in the working tree.
Use ‘–’ to separate paths from revisions, like this:
‘git […] – […]’
fatal: Not a valid object name HEAD
‘git […] – […]’
Component
Version
LibreNMS
DB Schema
251
PHP
7.2.6
MySQL
5.5.56-MariaDB
RRDTool
1.6.0
SNMP
NET-SNMP 5.7.2
[OK] Composer Version: 1.6.5
‘git […] – […]’
‘git […] – […]’
fatal: index file smaller than expected
[FAIL] DateTime::__construct(): Failed to parse time string (@) at position 0 (@): Unexpected character
[FIX] You can switch back to master with git checkout master
nothing to commit, working directory clean
[[email protected] .git]#
and something else
[[email protected] librenms]# ./daily.sh
‘git […] – […]’
‘git […] – […]’
fatal: Needed a single revision
fatal: No such ref: HEAD
Updating Composer packages OK
‘git […] – […]’
Updated from unset to OK
Updating SQL-Schema OK
Updating submodules FAIL
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
Not sure though, on my mobile but if you search these forums for “Whoops, looks like something went wrong” you can find fixes for that particular problem. but fixing git should help.
some issues gone but next will be same as previews
‘git […] – […]’
‘git […] – […]’
