Having issues with running LibreNMS in subdirectory on Apache / PHP on Fedora Core 33. When I follow the instructions as per the Sub-directory Support instructions, the site works, but some links are incorrectly formed, i.e. they have the subdirectory twice in the path.
For example, from one of my devices page, (https://domain.xyz/librenms/device/device=15/tab=edit/section=snmp/) I click on any of the links in the navigation bar (Device Settings, SNMP, Port Settings etc) they all have the subdirectory twice in the path which results in a 404 error from the webserver.
Example: (https://domain.xyz/librenms/librenms/device/device=15/tab=edit/section=snmp/)
Component | Version |
LibreNMS | 1.70.1-5-g8e718d6e4 |
DB Schema | 2020_10_12_095504_mempools_add_oids (191) |
PHP | 7.4.13 |
Python | 3.9.0 |
MySQL | 10.4.17-MariaDB |
RRDTool | 1.7.2 |
SNMP | NET-SNMP 5.9 |
LibreNMS httpd config:
$ cat /etc/httpd/conf.d/30-librenms.conf
#These directives can be inside a virtual host or in the base server configuration
AllowEncodedSlashes On
Alias /librenms /opt/librenms/html
<Directory “/opt/librenms/html”>
AllowOverride All
Options FollowSymLinks MultiViews
Order deny,allow
Require all granted
config.php setting:
This should only be set if you want to force a particular hostname/port
It will prevent the web interface being usable form any other hostname
$config[“base_url”] = ‘/librenms/’;
.htaccess setting:
RewriteBase /librenms
