LibreNMS installation does not appear to be updating to the latest
It looks like my installation of LibreNMS is not updating to the latest version. I ran the daily.sh and the validate.sh and have them pasted below. Please help.
librenms@e071librenms01:~$ ./daily.sh
Updating SQL-Schema OK
Cleaning up DB OK
librenms@e071librenms01:~$ ./validate.php
LibreNMS 25.6.0-5-g91ad01ffb (2025-06-17T14:02:12+00:00)
DB Schema 2025_06_11_173916_drop_alert_rule (344)
PHP 8.4.10
Python 3.12.3
Database MariaDB 10.11.13-MariaDB-0ubuntu0.24.04.1
SNMP 5.9.4.pre2
[OK] Composer Version: 2.8.9
PHP Error(2): stream_socket_client(): Unable to connect to tcp://127.0.0.1:6379 (Connection refused) from vendor/predis/predis/src/Connection/Resource/StreamFactory.php:209 in /opt/librenms/LibreNMS/Validations/Poller/CheckRedis.php:67
[WARN] Your install is over 24 hours out of date, last update: Tue, 17 Jun 2025 14:02:12 +0000
Nevermind, I ran the advanced user upgrade script and that took care of it.
