LibreNMS installation on NUTANIX AHV
I’m trying to install LibreNMS on NUTANIX AHV platform was failed. The ova files supported on NUTANIX?
Ova files sometimes do not work on Nutanix AHV if you specify the disk as SCSI. This is because the image is missing the KVM VirtIO drivers or they have not been properly compiled and activated in the kernel. It’s best to create an Ubuntu virtual machine and manually install LibreNMS. Optionally you can ask the creator of the ova image to create a KVM/Openstack compatible image.
