Librenms integrate with Azure OAuth 2.0
Hi there,
I am trying integrate our Librenms with Azure OAuth. Our Librenms is https but it is for internal network access only (not a public site).
I have followed the doc: Oauth/SAML support - LibreNMS Docs.
I have Login with Microsoft on login page now, and goes to Azure login page is fine as well. But after that, it is showing “Invalid credential”.
Call back address: https://192.168.10.10/auth/microsoft/callback has been setup in .env and App registrations already.
When I try to open https://192.168.10.10/auth/microsoft/callback, it shows “Whoops, something wrong message”, librenms.log is showing:
[2022-10-10T13:10:43.057771+13:00] production.ERROR: {“exception”:"[object] (Laravel\Socialite\Two\InvalidStateException(code: 0): at /opt/librenms/vendor/socialiteproviders/manager/src/O
Auth2/AbstractProvider.php:49)"}
Run trouble shooting command:
librenms@NQAKDVMSNM01:~$ lnms config:get auth.socialite
“redirect”: false,
“register”: false,
“configs”: {
“microsoft”: {
“client_id”: “2f4axxxxxxxxxxxxxxx”,
“client_secret”: “vKwxxxxxxxxxxxxxxxxxx”,
“tenant”: “a16xxxxxxxxxxxxxxxxxxxxxx”,
“listener”: “\SocialiteProviders\Microsoft\MicrosoftExtendSocialite”
Can anyone please give me an advice, thank you
Jeff Deng
You need to allow register probably, you can disable it later
Thank you my friend, it is working now after I set “register” as true.
Jeff Deng
