Librenms not detecting my system metrics
I tried to do as the instructions say, put config.php in /data/config but it didn’t work. I set the parameters through the console:
lnms config:set snmp.timeout 5
lnms config:set snmp.retries 10
lnms config:set snmp.exec_timeout 1200
It’s been about 15 minutes, nothing has changed.
ok. you are running librenms in docker
can u add container hostname instead of localhost
I had to delete localhost first. Added librenms, now I’m watching.
It works!
Maybe this should be added to the documentation?
Can you tell me what the default values were, I want them back.
And thanks for your help, it’s been almost 24 hours and everything is working fine.
lnms config:set snmp.timeout 1
lnms config:set snmp.retries 5
Ref: Configuration Docs - LibreNMS Docs
