gonzo
#1
I’ve added a few Citrix XenServers to LibreNMS which uses CentOS8 I believe.
It seems it can’t pull the right memory info in and instead uses their “Control domain memory” instead.
Here you can see what Citrix sees and is correct for 2 of our XenServers:
But LibreNMS only sees the 8GB and not 512GBs.
What can I do?
They most probably offer this information through a different OID/MIB that needs to be added in LibreNMS for XEN.
Do you have any MIB’s from Citrix ?
gonzo
#3
It seems the only way to get the real info is to SSH onto the Xen servers and run some Xen commands.
I think some other monitoring systems can run SSH into devices and run commands on behalf if the user, but I’m not sure LibreNMS can go to that level?
system
Closed
#4
