- The output of
./validate.php
LibreNMS | 22.2.1-23-g19e0ad604
DB Schema | 2022_02_03_164059_increase_auth_id_length (235)
PHP | 7.4.3
Python | 3.8.10
MySQL | 10.3.34-MariaDB-0ubuntu0.20.04.1
RRDTool | 1.7.2
SNMP | 5.8
[OK] Composer Version: 2.2.7
[FAIL] APP_KEY does not match key used to encrypt data. APP_KEY must be the same on all nodes.
** [FIX]:**
** If you rotated APP_KEY, run lnms key:rotate to resolve.**
[INFO] Detected Dispatcher Service
[WARN] Your install is over 24 hours out of date, last update: Fri, 11 Mar 2022 16:38:31 +0000
** [FIX]:**
** Make sure your daily.sh cron is running and run ./daily.sh by hand to see if there are any errors.**
** [FIX]:**
** You can fix this with ./scripts/github-remove**
** Modified Files:**
** app/Models/Device.php**
** resources/views/widgets/alerts.blade.php**
** resources/views/widgets/availability-map.blade.php**
Google Chrome , Firefox…ETC
HI Sir
My Librenms become slow when I open a page.
I think that I add many ping point (3xxx)
The Cpu is not full when i disable follow
#/5 * * * * librenms /opt/librenms/discovery.php -h new >> /dev/null 2>&1
#/5 * * * * librenms /opt/librenms/cronic /opt/librenms/poller-wrapper.py 16
#01 * * * * librenms /opt/librenms/billing-calculate.php >> /dev/null 2>&1
#*/5 * * * * librenms /opt/librenms/check-services.php >> /dev/null 2>&1
And I use distribute poller , so poller ping is other vm process.
PHP setting is only different the follow:
/etc/php/7.4/fpm# vim php.ini
; Maximum amount of memory a script may consume (128MB)
; PHP: Description of core php.ini directives - Manual
;memory_limit = 1024M(Marked)
Would any give me some idea !?
Many thanks!!
