I cannot get librenms and oxidized working the way I want. I have 2 groups in librenms, one Backup and the other Nobackup and I want only the devices in Backup group to be sent to oxidized for backup.
It seems (cf. doc feeding oxidized in librenms) that lnms config:set oxidized.ignore_groups '["Nobackup"]' would do the job, but it doesn’t seem to work (i.e. every device is polled for backup by oxidized). When I go in the UI Settings > External > oxidized, it seems this setting concerns “Do not backup these Oxidized groups”, so no librenms groups…
Did I miss something in the docs, or this should be working and doesn’t?
Thanks for any hint.
validate.php:
LibreNMS | 25.4.0 (2025-04-14T14:11:19+02:00)
DB Schema | 2025_03_22_134124_fix_ipv6_addresses_id_type (331)
PHP | 8.2.28
Python | 3.11.2
Database | MariaDB 10.11.11-MariaDB-0+deb12u1
RRDTool | 1.7.2
SNMP | 5.9.3
[OK] Composer Version: 2.8.8
result of lnms config:get oxidized (section os pruned, it’s the default):
"default_group": null,
"ignore_groups": [
"Nobackup"
"enabled": true,
"features": {
"versioning": true
"group_support": true,
"ignore_os": [],
"ignore_types": [
"Environment",
"Firewall",
"Server"
"maps": {
"os": {
"reload_nodes": true,
"url": "http://127.0.0.1:8888"
oxydized config:
username: oxidized
password: myultrasecurepassword
resolve_dns: true
interval: 3600
use_syslog: false
debug: false
run_once: false
threads: 30
use_max_threads: false
timeout: 20
retries: 3
next_adds_job: false
vars: {}
groups: {}
group_map: {}
pid: "/etc/oxidized/.config/oxidized/pid"
extensions:
oxidized-web:
load: true
listen: 127.0.0.1
port: 8888
vhosts:
- localhost
- 127.0.0.1
crash:
directory: "/etc/oxidized/.config/oxidized/crashes"
hostnames: false
stats:
history_size: 10
input:
default: ssh, telnet
debug: false
ssh:
secure: false
utf8_encoded: true
output:
default: git
git:
user: Oxidized
single_repo: true
repo: /etc/oxidized/devices.git
source:
default: http
debug: false
http:
url: https://librenms.grenoble-inp.fr/api/v0/oxidized
scheme: https
secure: false
map:
model: os
group: group
headers:
X-Auth-Token: ea99624895220e6c7518f77c90dd9588
model_map:
juniper: junos
cisco: ios
