@Jellyfrog : Yes sir. I am trying to deploy REDIS so that I can make it talk to other pollers in the network. We are currently operating on a single instance of LibreNMS that is consuming humongous resources and it cant handle about 1300 devices on it’s own.
Earlier I thought that the server stopped polling but then I realized that it is somehow interfering with the Web GUI but the device polling and stats collection is happening in the background.
I have turned off the protected mode on the REDIS-SERVER conf and commented out the bind statement. It seems to have stopped blocking the web GUI from working and I see it working even when REDIS is mentioned in the .env file.
The same doesn’t seem to get along when I deployed it in the CentOS environment. This is the error log that I found on the CentOS deployment.
[previous exception] [object] (Predis\Connection\ConnectionException(code: 13): Permission denied [tcp://10.28.132.61:6379] at /opt/librenms/vendor/predis/predis/src/Connection/AbstractConnection.php:155)
[stacktrace]
#0 /opt/librenms/vendor/predis/predis/src/Connection/StreamConnection.php(128): Predis\Connection\AbstractConnection->onConnectionError(‘Permission deni…’, 13)
#1 /opt/librenms/vendor/predis/predis/src/Connection/StreamConnection.php(178): Predis\Connection\StreamConnection->createStreamSocket(Object(Predis\Connection\Parameters), ‘tcp://10.28.132…’, 4)
#2 /opt/librenms/vendor/predis/predis/src/Connection/StreamConnection.php(100): Predis\Connection\StreamConnection->tcpStreamInitializer(Object(Predis\Connection\Parameters))
#3 /opt/librenms/vendor/predis/predis/src/Connection/AbstractConnection.php(81): Predis\Connection\StreamConnection->createResource()
#4 /opt/librenms/vendor/predis/predis/src/Connection/StreamConnection.php(258): Predis\Connection\AbstractConnection->connect()
#5 /opt/librenms/vendor/predis/predis/src/Connection/AbstractConnection.php(180): Predis\Connection\StreamConnection->connect()
#6 /opt/librenms/vendor/predis/predis/src/Connection/StreamConnection.php(288): Predis\Connection\AbstractConnection->getResource()
\7 /opt/librenms/vendor/predis/predis/src/Connection/StreamConnection.php(394): Predis\Connection\StreamConnection->write(’*2
\3
\ET
$5…’)
#8 /opt/librenms/vendor/predis/predis/src/Connection/AbstractConnection.php(110): Predis\Connection\StreamConnection->writeRequest(Object(Predis\Command\StringGet))
#9 /opt/librenms/vendor/predis/predis/src/Client.php(331): Predis\Connection\AbstractConnection->executeCommand(Object(Predis\Command\StringGet))
#10 /opt/librenms/vendor/predis/predis/src/Client.php(314): Predis\Client->executeCommand(Object(Predis\Command\StringGet))
#11 /opt/librenms/vendor/laravel/framework/src/Illuminate/Redis/Connections/Connection.php(116): Predis\Client->__call(‘get’, Array)
#12 /opt/librenms/vendor/laravel/framework/src/Illuminate/Redis/Connections/Connection.php(220): Illuminate\Redis\Connections\Connection->command(‘get’, Array)
#13 /opt/librenms/vendor/laravel/framework/src/Illuminate/Cache/RedisStore.php(62): Illuminate\Redis\Connections\Connection->__call(‘get’, Array)
#14 /opt/librenms/vendor/laravel/framework/src/Illuminate/Cache/Repository.php(97): Illuminate\Cache\RedisStore->get(‘checks_popup_ti…’)
#15 /opt/librenms/vendor/laravel/framework/src/Illuminate/Cache/CacheManager.php(418): Illuminate\Cache\Repository->get(‘checks_popup_ti…’)
#16 /opt/librenms/vendor/laravel/framework/src/Illuminate/Support/Facades/Facade.php(261): Illuminate\Cache\CacheManager->__call(‘get’, Array)
#17 /opt/librenms/app/Checks.php(43): Illuminate\Support\Facades\Facade::__callStatic(‘get’, Array)
#18 /opt/librenms/app/Http/ViewComposers/LayoutComposer.php(52): App\Checks::postAuth()
#19 /opt/librenms/vendor/laravel/framework/src/Illuminate/View/Concerns/ManagesEvents.php(124): App\Http\ViewComposers\LayoutComposer->compose(Object(Illuminate\View\View))
#20 /opt/librenms/vendor/laravel/framework/src/Illuminate/Events/Dispatcher.php(392): Illuminate\View\Factory->Illuminate\View\Concerns\{closure}(Object(Illuminate\View\View))
#21 /opt/librenms/vendor/laravel/framework/src/Illuminate/Events/Dispatcher.php(237): Illuminate\Events\Dispatcher->Illuminate\Events\{closure}(‘composing: layo…’, Array)
#22 /opt/librenms/vendor/laravel/framework/src/Illuminate/View/Concerns/ManagesEvents.php(177): Illuminate\Events\Dispatcher->dispatch(‘composing: layo…’, Array)
#23 /opt/librenms/vendor/laravel/framework/src/Illuminate/View/View.php(120): Illuminate\View\Factory->callComposer(Object(Illuminate\View\View))
#24 /opt/librenms/vendor/laravel/framework/src/Illuminate/View/View.php(91): Illuminate\View\View->renderContents()
#25 /opt/librenms/storage/framework/views/3a1e3c9b836cc6723962e6cc8198f744923dbfb0.php(11): Illuminate\View\View->render()
#26 /opt/librenms/vendor/laravel/framework/src/Illuminate/Filesystem/Filesystem.php(107): require(’/opt/librenms/s…’)
#27 /opt/librenms/vendor/laravel/framework/src/Illuminate/Filesystem/Filesystem.php(108): Illuminate\Filesystem\Filesystem::Illuminate\Filesystem\{closure}()
#28 /opt/librenms/vendor/laravel/framework/src/Illuminate/View/Engines/PhpEngine.php(58): Illuminate\Filesystem\Filesystem->getRequire(’/opt/librenms/s…’, Array)
#29 /opt/librenms/vendor/laravel/framework/src/Illuminate/View/Engines/CompilerEngine.php(61): Illuminate\View\Engines\PhpEngine->evaluatePath(’/opt/librenms/s…’, Array)
#30 /opt/librenms/vendor/laravel/framework/src/Illuminate/View/View.php(139): Illuminate\View\Engines\CompilerEngine->get(’/opt/librenms/r…’, Array)
#31 /opt/librenms/vendor/laravel/framework/src/Illuminate/View/View.php(122): Illuminate\View\View->getContents()
#32 /opt/librenms/vendor/laravel/framework/src/Illuminate/View/View.php(91): Illuminate\View\View->renderContents()
#33 /opt/librenms/vendor/laravel/framework/src/Illuminate/Http/Response.php(69): Illuminate\View\View->render()
#34 /opt/librenms/vendor/laravel/framework/src/Illuminate/Http/Response.php(35): Illuminate\Http\Response->setContent(Object(Illuminate\View\View))
#35 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(793): Illuminate\Http\Response->__construct(Object(Illuminate\View\View), 200, Array)
#36 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(763): Illuminate\Routing\Router::toResponse(Object(Illuminate\Http\Request), Object(Illuminate\View\View))
#37 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(695): Illuminate\Routing\Router->prepareResponse(Object(Illuminate\Http\Request), Object(Illuminate\View\View))
#38 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#39 /opt/librenms/app/Http/Middleware/RedirectIfAuthenticated.php(30): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#40 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\RedirectIfAuthenticated->handle(Object(Illuminate\Http\Request), Object(Closure))
#41 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(50): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#42 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Routing\Middleware\SubstituteBindings->handle(Object(Illuminate\Http\Request), Object(Closure))
#43 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/VerifyCsrfToken.php(78): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#44 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure))
#45 /opt/librenms/vendor/laravel/framework/src/Illuminate/View/Middleware/ShareErrorsFromSession.php(49): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#46 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure))
#47 /opt/librenms/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(121): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#48 /opt/librenms/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(64): Illuminate\Session\Middleware\StartSession->handleStatefulRequest(Object(Illuminate\Http\Request), Object(Illuminate\Session\Store), Object(Closure))
#49 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure))
#50 /opt/librenms/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/AddQueuedCookiesToResponse.php(37): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#51 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure))
#52 /opt/librenms/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/EncryptCookies.php(67): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#53 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure))
#54 /opt/librenms/app/Http/Middleware/CheckInstalled.php(61): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#55 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\Http\Middleware\CheckInstalled->handle(Object(Illuminate\Http\Request), Object(Closure))
#56 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#57 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(697): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#58 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(672): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request))
#59 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(636): Illuminate\Routing\Router->runRoute(Object(Illuminate\Http\Request), Object(Illuminate\Routing\Route))
#60 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(625): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request))
#61 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(166): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request))
#62 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request))
#63 /opt/librenms/vendor/genealabs/laravel-caffeine/src/Http/Middleware/LaravelCaffeineDripMiddleware.php(11): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#64 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): GeneaLabs\LaravelCaffeine\Http\Middleware\LaravelCaffeineDripMiddleware->handle(Object(Illuminate\Http\Request), Object(Closure))
#65 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#66 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php(31): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle(Object(Illuminate\Http\Request), Object(Closure))
#67 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\ConvertEmptyStringsToNull->handle(Object(Illuminate\Http\Request), Object(Closure))
#68 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#69 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php(40): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle(Object(Illuminate\Http\Request), Object(Closure))
#70 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\TrimStrings->handle(Object(Illuminate\Http\Request), Object(Closure))
#71 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#72 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\ValidatePostSize->handle(Object(Illuminate\Http\Request), Object(Closure))
#73 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(86): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#74 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance->handle(Object(Illuminate\Http\Request), Object(Closure))
#75 /opt/librenms/vendor/fruitcake/laravel-cors/src/HandleCors.php(38): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#76 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Fruitcake\Cors\HandleCors->handle(Object(Illuminate\Http\Request), Object(Closure))
#77 /opt/librenms/vendor/fideloper/proxy/src/TrustProxies.php(57): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#78 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Fideloper\Proxy\TrustProxies->handle(Object(Illuminate\Http\Request), Object(Closure))
#79 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#80 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(141): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#81 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(110): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request))
#82 /opt/librenms/html/index.php(52): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request))
#83 {main}
