Librenms Python3 module issue found
[email protected]:~$ ./validate.php
LibreNMS | 21.11.0-8-g1935358
DB Schema | 2021_11_12_123037_change_cpwVcID_to_unsignedInteger (225)
PHP | 7.4.12
Python | 3.5.2
MySQL | 10.4.18-MariaDB-1:10.4.18+maria~xenial
RRDTool | 1.5.5
SNMP | NET-SNMP 5.7.3
[OK]    Composer Version: 2.1.12
[FAIL]  Python3 module issue found: ''
	pip3 install -r /opt/librenms/requirements.txt
[WARN]  Your local git contains modified files, this could prevent automatic updates.
	Modified Files:
	 includes/definitions/eltex-mes.yaml
I try to run pip3 install -r /opt/librenms/requirements.txt but no luck, got again this error.
Problem solved.
What was the resolution? I’m having a similar problem.
In my case, problem was in Python 3.5, I just update my ubuntu server 16.04 to 20.04 and python to 3.8 version
