LibreNMS - Re-discovery
We are encountering an issue with the 6-hour rediscovery process in LibreNMS. Despite having disabled the discovery service and specific discovery modules, the rediscovery process continues to occur at regular 6-hour intervals. Please note that we are using LibreNMS within a Docker containerized environment.
Disabled discovery service:
docker exec -it librenms_dispatcher lnms config:get service_discovery_enabled
false
Potential Cause:
The following cron job might be responsible for the 6-hour rediscovery on existing devices:
docker exec -it librenms_dispatcher cat /opt/librenms/dist/librenms.cron
          • librenms /opt/librenms/alerts.php >> /dev/null 2>&1
19 0 * * * librenms /opt/librenms/daily.sh >> /dev/null 2>&1
Question:
Despite the discovery service being disabled, do cron jobs continue to trigger?
What’s Librenms behaviour in this case?
Please help me out how to turn off 6 hours re-discovery in LibreNMS, We would like to perform re-discovery(for already added devices) every 24 hrs at a partcular time rather than default 6 hrs.
/opt/librenms $ ./validate.php
LibreNMS 23.11.0 (2023-11-25T19:17:34+00:00)
DB Schema 2023_11_04_125846_packages_increase_name_column_length (273)
PHP 8.1.22
Python 3.10.13
Database MariaDB 10.5.24-MariaDB-1:10.5.24+maria~ubu2004
SNMP 5.9.3
[OK] MySQl and PHP time match
[OK] Redis is functional
If you are using cron then service_discovery_enabled has no affect.
Just edit the cron file to change it to run discovery-wrapper.py every 24 hours.
