hi, I modified the access to the mariadb database so that it is understood that I corrected since which source ip was connected to the database.
After that he began to record data but he does not bring me the old data.
Can you give me a hand?
./validate.php
| LibreNMS | 22.9.0-3-g06c361c2b |
| DB Schema | 2022_09_03_091314_update_ports_adsl_table_with_defaults (246) |
| PHP | 7.4.33 |
| Python | 3.6.8 |
| Database | MariaDB 10.3.28-MariaDB |
| RRDTool | 1.7.0 |
| SNMP | 5.8 |
[OK] Composer Version: 2.8.8
[OK]
[OK] MySQl and PHP time match
[WARN] PHP version 8.1 is the minimum supported version as of September, 2022. We recommend you update PHP to a supported version (8.1 suggested) to continue to receive updates. If you do not update PHP, LibreNMS will continue to function but stop receiving bug fixes and updates.
[FAIL] No active polling method detected
[WARN] Your install is over 24 hours out of date, last update: Thu, 29 Sep 2022 04:32:10 +0000
You can switch back to master with git checkout master
Modified Files:
resources/views/alerts/templates/default.blade.php
rrd/.gitignore
