Steps to reproduce an issue.
If you go to ports then down nothing shows in the list, but it still shows 1 in the drop down. -
The output of
./validate.php
root@jitsi:/opt/librenms# php validate.php
LibreNMS | 1.51-52-g312d35dd9
DB Schema | 2019_02_10_220000_add_dates_to_fdb (132)
PHP | 7.2.18-1+0~20190503103213.21+stretch~1.gbp101320
MySQL | 10.1.38-MariaDB-0+deb9u1
RRDTool | 1.6.0
SNMP | NET-SNMP 5.7.3
[OK] Composer Version: 1.8.5
If you are having troubles with discovery/polling include the
pastebin output of:./discovery.php -h HOSTNAME -d | ./pbin.sh
