My LibreNMS seated on version 1.33, it unable to update to latest version.
Is there anyone can help?
Component | Version |
LibreNMS | 1.33-320-g4be1755 |
DB Schema | 228 |
PHP | 7.0.25 |
MySQL | 5.5.56-MariaDB |
RRDTool | 1.6.0 |
SNMP | NET-SNMP 5.7.2 |
DB Schema | 228 |
PHP | 7.0.25 |
RRDTool | 1.6.0 |
Hi Kevin,
Thank you for your reply.
As I saw the latest version is 1.35 in LibreNMS Docs, isn’t it?
Yes, that is the Stable branch which follows the 1.3x etc.
You are on the master branch which receives daily updates. Don’t worry about the 1.33 it’s the other part that tells you are getting updates. 320-g4be1755 Again you are are up to date.
There was an issue with the tagging so the development version does not show 1.35, which has been corrected. It is only cosmetic.
If you want to fix it in your local install run git pull --tags
as the librenms user.
