LDAP Authentication is working and I am also able to login on LibreNME Web Console. But After Logging into Web console, I dont have any rights. I am member of GROUP_RW group still no rights. I dont see any devices.
./validate.php
| LibreNMS | 23.10.0 (2023-10-27T05:47:36+02:00) |
| DB Schema | 2023_10_20_075853_cisco_asa_add_default_limits (268) |
| PHP | 8.1.2-1ubuntu2.14 |
| Python | 3.10.12 |
| Database | MariaDB 10.6.12-MariaDB-0ubuntu0.22.04.1 |
| RRDTool | 1.7.2 |
| SNMP | 5.9.1 |
[OK] Composer Version: 2.6.4
[OK] MySQl and PHP time match
./scripts/auth_test.php -u amit
Authentication Method: ldap
Password:
Authenticate user amit:
AUTH SUCCESS
User (1234567):
username => amit
realname => Batham Amit
user_id => 1234567
email => yxz.com
level => 10
Groups: ; cn=GROUP_RW,ou=Groups,o=ABC; cn=GROUP_RO,ou=Groups,o=ABC
grep auth_ config.php
#$config[‘auth_mechanism’] = “mysql”; # default, other options: ldap, http-auth
#$config[‘http_auth_guest’] = “guest”; # remember to configure this user if you use http-auth
$config[‘auth_mechanism’] = ‘ldap’;
$config[‘auth_ldap_server’] = ‘ldaps://ABC.com’;
$config[‘auth_ldap_suffix’] = ‘,ou=Internal,ou=People,o=ABC’;
$config[‘auth_ldap_groupbase’] = ‘ou=Groups,o=ABC’;
$config[‘auth_ldap_groups’][‘GROUP_RW’][‘level’] = 10;
$config[‘auth_ldap_groups’][‘GROUP_RO’][‘level’] = 5;
$config[‘auth_ldap_userdn’] = true;
$config[‘auth_ldap_prefix’] = ‘uid=’;
$config[‘auth_ldap_dn_prefix’] = ‘employeeNumber=’;
$config[‘auth_ldap_groupmemberattr’] = ‘member’;
$config[‘auth_ldap_uid_attribute’] = ‘employeeNumber’;
$config[‘auth_ldap_userlist_filter’] = ‘&(objectclass=person)(|(abcMemberOf=GROUP_RW)(abcMemberOf=GROUP_RO))’;
$config[‘auth_ldap_binddn’] = ‘cn=dnuser,ou=SystemUsers,ou=Accounts,o=ABC’;
$config[‘auth_ldap_bindpassword’] = ‘xxxxxxxxxx’;
$config[‘auth_ldap_bindanonymous’] = FALSE;
grep -Ew getUser LibreNMS/Authentication/LdapAuthorizer.php -A10
public function getUser($user_id)
$connection = $this->getLdapConnection();
$filter = '(' . Config::get('auth_ldap_prefix') . $this->userloginname . ')';
if (Config::get('auth_ldap_userlist_filter') != null) {
$filter = '(' . Config::get('auth_ldap_userlist_filter') . ')';
$search = ldap_search($connection, trim(Config::get('auth_ldap_suffix'), ','), $filter);
$entries = ldap_get_entries($connection, $search);
