When I attempt to add my MacBook Pro to LibreNMS, I get the following messages:
Adding host 192.168.8.26 community XXXXXXXXXXXXXX port 161 using udp
Could not connect to 192.168.8.26, please check the snmp details and snmp reachability
SNMP v2c: No reply with community XXXXXXXXXXXXX
Validate.php gives OK on all lines
[email protected]:/opt/librenms# ./discovery.php -h 192.168.8.26 -d | ./pbin.sh
Paste endpoint: https://p.libren.ms/api/create
title:
private: 1
expire: 0
https://p.libren.ms/view/d33c82ab
LibreNMS Discovery
SQL[[1;33mselect `migration` from `migrations` order by `id` desc limit 1 [0;33m[][0m 1.26ms]
SQL[[1;33mselect count(*) as aggregate from `migrations` [0;33m[][0m 0.96ms]
SQL[[1;33mselect version() [0;33m[][0m 0.86ms]
LibreNMS | 22.10.0 (2022-10-29T01:28:22+00:00)
DB Schema | 2022_09_03_091314_update_ports_adsl_table_with_defaults (248)
PHP | 8.1.2-1ubuntu2.6
Python | 3.10.6
Database | MariaDB 10.6.7-MariaDB-2ubuntu1.1
RRDTool | 1.7.2
SNMP | 5.9.1
DEBUG!
Updating os_def.cache
SQL[[1;33mSELECT * FROM `devices` WHERE disabled = 0 AND `hostname` LIKE 'XLHou008026' ORDER BY device_id DESC [0;33m[][0m 0.76ms]
./discovery.php XLHou008026 2022-10-31 21:02:29 - 0 devices discovered in 0.388 secs
[0;36mSNMP[0m [0/0.00s]:
[1;33mSQL[0m [5/0.04s]: Select[5/0.04s]
[0;32mRRD[0m [0/0.00s]:
title:
private: 1
expire: 0
https://p.libren.ms/view/c6b81525
LibreNMS Discovery
SQL[[1;33mselect `migration` from `migrations` order by `id` desc limit 1 [0;33m[][0m 0.45ms]
SQL[[1;33mselect count(*) as aggregate from `migrations` [0;33m[][0m 0.33ms]
SQL[[1;33mselect version() [0;33m[][0m 0.31ms]
Python | 3.10.6
RRDTool | 1.7.2
SNMP | 5.9.1
DEBUG!
SQL[[1;33mSELECT * FROM `devices` WHERE disabled = 0 AND `hostname` LIKE '192.168.8.26' ORDER BY device_id DESC [0;33m[][0m 0.87ms]
./discovery.php 192.168.8.26 2022-10-31 21:03:51 - 0 devices discovered in 0.367 secs
[1;33mSQL[0m [5/0.03s]: Select[5/0.03s]
[email protected]:/opt/librenms# ./poller.php -h XLHou008026 -r -f -d ./pbin.sh
LibreNMS Poller
SQL[select `migration` from `migrations` order by `id` desc limit 1 [] 1.89ms]
SQL[select count(*) as aggregate from `migrations` [] 2.22ms]
SQL[select version() [] 2.78ms]
Python | 3.10.6
RRDTool | 1.7.2
SNMP | 5.9.1
DEBUG!
Starting polling run:
SQL[SELECT * FROM `devices` WHERE `disabled` = 0 AND `hostname` = 'XLHou008026' ORDER BY `device_id` ASC [] 6.63ms]
./poller.php XLHou008026 2022-10-31 21:29:09 - 0 devices polled in 0.948 secs
SNMP [0/0.00s]:
SQL [5/0.15s]: Select[5/0.15s]
