LibreNMS working with InfluxDB
I have been working to get LibreNMS set up with InfluxDB. I have created the DB in Influx and added the configs to config.php and validate.php does not show any errors. I have looked at the SERIES in the Influx DB librenms databse and I see that there something there but there isn’t any data associated with the series info.
When I debug the connection between LibreNMS and Influx I see the following error:
15:25:59.723808 IP (tos 0x0, ttl 64, id 57462, offset 0, flags [DF], proto TCP (6), length 52)
localhost.8086 > localhost.37620: Flags [F.], cksum 0xfe28 (incorrect -> 0x1937), seq 111586, ack 236829, win 6721, options [nop,nop,TS val 135066 ecr 135066], length 0
15:25:59.723824 IP (tos 0x0, ttl 64, id 38492, offset 0, flags [DF], proto TCP (6), length 52)
localhost.37620 > localhost.8086: Flags [.], cksum 0xfe28 (incorrect -> 0x2770), seq 236829, ack 111587, win 3080, options [nop,nop,TS val 135066 ecr 135066], length 0
When I look at the PCAP file I would expect to see a POST that contains data that looks like POST cpu,host=serverA,region=us_west value=0.64… But I just see Data: 706f6c6 etc.
I am not an Influx or LibreNMS guru so any help to figure this out would be greatly appreciated.
Thank you.
-Patrick
