Hi, Its running off a UCS VM. 20 Cores, 32GB RAM, SSDs for Hard Drives. I have about 2000 devices added and 40,000 ports. I am syslogging about 100 devices. I would like to syslog the rest but as of right now in /etc/systemd/journald.conf the rate limit is commented out. Is that normal for RAM to be this high?
What do you mean spec to be? Should I increase the resources to my VM? Is there a doc to split the MySQL and what big benefits will that give me? Thank You.
Sorry should have said out of the spec to be honest. I.e I’m surprised it’s working.
Splitting mysql off is just a case of installing mysql on a new server, dump the database, import into new server and change config.php to use the new DB server.
So what specs would I need for 2000 devices if kept on the same server?
So splitting my MySQL to another machine how much resources will the 1st and 2nd need to be?
If it’s working for you then you already know the specs you need, it’s extremely difficult to calculate required resources accurately.
For 3.5k devices, we run a 12 core, 32gb ram, 120gb ssd x 2 in raid 1 on physical kit and it’s fairly under utilised so you should be able to cope with half of that if not less.
Hmm for some reason the memory keeps inclining, I gave it about 128gb and has used almost all of it. In going to try and split off the database hopefully that helps. It seems like there are a lot of mysqld plugin running filling up the memory?
Will that be reduced if put the database on another vm?
Also, check to see if you have any really large tables, like syslog or something. There was an issue with perf_log not getting cleaned out by daily.sh for awhile.
Will do, I am in the process of moving the SQL database off to another server like was mentioned earlier. Seems like the poller-wrapper proccess keep running.
Nope doesn’t seem to get stuck the only thing that does take a while is the discovery-wrapper.py takes about an hour to run. It only runs by the default cron
