How do I get my LIbrenms to monitor apps, pkgs processes?
The localhost currently everything working but the correct storage.
localhost
another server
localhost
another server
Yes, you would need installed setup this on each Linux server you are monitoring. https://docs.librenms.org/Extensions/Agent-Setup/
Thank you, I had done the agent install but I didnt open the port
Once the processed are being captured by the agent how do you then set up alerts for processes not being up etc?
