Couldnt see an lnms command to Disable polling and alerting for a device (which is done via the WebUI, cog button, click then save).
This might be useful … or is it API only?
No command to edit devices. No one has ever requested the option to edit devices from the CLI before. If this is a common occurrence you could create your own script that calls the API.
OK makes sense, will use API if i need to do it again
