Lnms config:set os.<os>.discovery_modules.<discovery module> not working for aos6 or aos7
Greetings.
I’m trying to configure some discovery module settings for aos6 and aos7 using lnms, and it’s responding that it’s not a valid setting:
librenms@LibreNMS:~$ lnms config:set os.aos7.discovery_modules.bgp-peers false
This is not a valid setting. Please check your input
I can configure discovery_modules for other os’es (such as iosxr). Is there something that is preventing the configuration of discovery_modules specifically for aos6 and aos7?
librenms@LibreNMS:~$ ./validate.php
LibreNMS 26.7.0 (2026-07-20T10:51:00-05:00)
DB Schema 2026_07_17_140739_change_interference_to_small_int_access_points_table (394)
PHP 8.3.6
Python 3.12.3
SNMP 5.9.4.pre2
[OK] Composer Version: 2.10.2
[OK] No active python wrapper pollers found
Thanks.
