Hello all ,
I’m having issues when running validate.php it states that my database is out of date , this can be fixed by running ./lnms migrate.
But after running the migrate command I get these errors .
Migrating: 2020_04_06_001048_the_great_index_rename
In Connection.php line 669:
SQLSTATE[42000]: Syntax error or access violation: 1091 Can’t DROP ‘deleted’; check that column/key exists (SQL: ALTER TABLE access_points DROP INDEX deleted, ADD INDEX access_points_deleted_index(
deleted)
In PDOStatement.php line 129:
In PDOStatement.php line 127:
I’d appreciate any help you can provide
Thanks ,
Same here on Monthly update channel after installing the Python3 requirements.
Your system failed to apply the migration fully.
- Mark the migration as completed
insert into migrations (migration, batch) VALUES ("2020_04_06_001048_the_great_index_rename", 1);
- run
./validate.php or lnms migrate --pretend
- Run the suggested SQL statements until validation comes back clean.
- If you have any inconsistencies that persist, ask for more help
Following murrant’s steps solved the issue .
Thanks !
Dear Murrent ! i have facing same issue please tell me how i execute the command in step 1 ?
librenms@netplus-NMS:~$ ./validate.php
| Component |
Version |
| LibreNMS |
21.2.0-8-g3d5f4bdad |
| DB Schema |
(0) |
| PHP |
7.4.3 |
| Python |
3.8.5 |
| MySQL |
10.3.25-MariaDB-0ubuntu0.20.04.1 |
| RRDTool |
1.7.2 |
| SNMP |
NET-SNMP 5.8 |
[OK] Composer Version: 2.0.9
[WARN] You have no devices.
Consider adding a device such as localhost: /addhost
./lnms migrate
Dear Murrant !
i ve facing same problem !
librenms@netplus-NMS:~$ ./lnms migrate
yes
Loading stored database schema: /opt/librenms/database/schema/mysql-schema.dump
In Process.php line 267:
The command “mysql --user=”${:LARAVEL_LOAD_USER}" --password=“${:LARAVEL_LOAD_PASSWORD}” --host=“${:LARAVE
L_LOAD_HOST}” --port=“${:LARAVEL_LOAD_PORT}” --database=“${:LARAVEL_LOAD_DATABASE}” < “${:LARAVEL_LOAD_PATH
}”" failed.
Exit Code: 1(General error)
Working directory: /opt/librenms
Output:
Error Output:
ERROR 1050 (42S01) at line 9: Table ‘access_points’ already exists
