Hi all,
i tried to update LibreNMS today but during the update process i run in some error.
I was running an older version of LibreNMS and in the t´first steps i had to update the php version and mariadb. Now i’m up to date with the versions but i still get some error:
See Validate.php
bash-4.2$ ./validate.php
LibreNMS | 21.12.0
DB Schema | 2020_12_14_091314_create_port_group_port_table (199)
PHP | 7.4.27
Python | 3.6.8
MySQL | 10.5.13-MariaDB
RRDTool | 1.4.8
SNMP | 5.7.2
[OK] Composer Version: 2.2.0
./lnms migrate
Then i try to migrate
bash-4.2$ ./lnms migrate
* Application In Production! *
> yes
Migrating: 2020_12_14_091314_create_port_groups_table
In Connection.php line 703:
SQLSTATE[HY000]: General error: 1709 Index column size too large. The maximum column size is 767 bytes (SQL: alter table `port_groups` add unique `port_groups_name_unique`(`name`))
In Exception.php line 18:
In PDOStatement.php line 117:
I found a lot of posts here where the mariadb version was wrong. But i’m now on the lastest version.
Any suggestions what i can do to fix the error?
