I updated my LibreNMS docker container (x86 debian host) today and found that I had to update the DB which is fine but I’m getting the following error and I haven’t been able to find a fix
Everything seems to be working fine, I was on 1.55 or 1.58 from memory and upgraded to fix the graph timezone not being correct.
I’ve tried running the command as the default bash login for the docker & using ‘su librenms’
I’ve also run the command with --pretend switch and it appears to complete successfully but if I run ./daily.sh and then ./validate.sh I still get the ./lnms migrate error
Any suggestions on a resolution would be appreciated!
**Error Output **
bash-5.0# su librenms
/opt/librenms $ ./lnms migrate
Application In Production! *
yes
Migrating: 2020_04_06_001048_the_great_index_rename
In Connection.php line 671:
SQLSTATE[42000]: Syntax error or access violation: 1091 Can’t DROP INDEX deleted; check that it exists (SQL: ALTER TABLE access_points DROP INDEX deleted, ADD INDEX access_points_deleted_index(deleted);
In PDOStatement.php line 129:
In PDOStatement.php line 127:
In SchemaException.php line 85:
There is no column with name ‘availability_perc’ on table ‘availability’.
/opt/librenms $
** ./validate **
/opt/librenms $ ./validate.php
| LibreNMS | 1.66 |
| DB Schema | 2020_03_25_165300_add_column_to_ports (162) |
| PHP | 7.3.20 |
| Python | 3.8.5 |
| MySQL | 10.2.33-MariaDB-1:10.2.33+maria~bionic |
| RRDTool | 1.7.2 |
| SNMP | NET-SNMP 5.8 |
./lnms migrate
/opt/librenms $
