./lnms migrate no column availability_perc
Hello All,
I have issue when fixed database out of date . When I running ./lnms migrate --pretend is failed with :
In SchemaException.php line 85:
There is no column with name 'availability_perc' on table 'availability'.
I’d appreciate any help you can provide
what says validate.php ?
./validate.php
LibreNMS 1.64.1-356-gd75cc52
DB Schema 2020_03_25_165300_add_column_to_ports (162)
PHP 7.2.17
Python 3.6.8
MySQL 5.5.60-MariaDB
RRDTool 1.4.8
SNMP NET-SNMP 5.7.2
[OK] Composer Version: 1.10.8
./lnms migrate
validate.php still like that.
what happens if you run “./lnms migrate” as user librenms ?
Im having the same issue and I am running the migrate as librenms user
I got a similar problem.
[email protected]:~# su - librenms
[email protected]:~$ ./lnms migrate
  • Application In Production!     *
yes
Migrating: 2021_03_17_160729_service_templates_cleanup
In SchemaException.php line 86:
There is no column with name ‘type’ on table ‘service_templates’.
[email protected]:~$ ./validate.php
LibreNMS 21.8.0
DB Schema 2021_02_21_203415_location_add_fixed_coordinates_flag (204)
PHP 7.3.25-1+ubuntu18.04.1+deb.sury.org+1
Python 3.6.9
MySQL 10.5.12-MariaDB-1:10.5.12+maria~bionic
RRDTool 1.7.0
SNMP NET-SNMP 5.7.3
[OK] Composer Version: 2.1.6
./lnms migrate
Modified Files:
config/database.php
[FAIL] We have found some files that are owned by a different user than ‘librenms’, this will stop you updating automatically and / or rrd files being updated causing graphs to fail.
Files:
/opt/librenms/.mysql_history
@SourceDoctor , @lucasv92 , @Jellyfrog , @murrant
Please let me know if you have come across a fix for this problem. This looks like the last leg to bring my monitoring instance online.
Thanks,
Santosh Kotla
