I have searched through the help requests and they all point to a section of the docs that I can’t seem to find (extensions/memcached). I am attempting to setup distributed polling and want to make sure everything is configured correctly, but am missing the initial piece of the puzzle.
I have started following the docs, but am getting a couple errors.
For reference my setup is as follows:
1 LibreNMS server running full install via install docs for ubuntu and nginx (web, db, poller, etc)
2 Working to configure poller at remote sites to handle snmp/icmp polling of devices local to the remote poller
3 installed memcached via apt install memcached
4 installed rrdcached via apt install rrdcached (followed rrdcached install doc for original install) made changes to the rrdcached file (/etc/default/rrdcached) per distributed poller doc
When I run ./validate.php is says missing php extension: memcached and cannot connect to rrdcached instance
I think I have the primary server working correctly. Now for the remote poller.
Quick question for clarification: on the remote poller, when I install LibreNMS per the docs, can I skip the DB install and point to the primary server in the configuration?
