Hello all,
For networks with VRFs but no route distinguishes, it seems that NMS has some difficulty displaying VRF information. I have an idea of what is happening in the code, but I’m curious what the VRF page looks like for others.
For me, I get this (nothing):
What do you guys get on your overall VRF page (not on a per device basis)?
Edit:
The ./validate.php for production NMS
Component | Version |
LibreNMS | 1.40-2-g48f06bb |
DB Schema | 251 |
PHP | 7.2.5 |
MySQL | 5.7.21-20-57-log |
RRDTool | 1.6.0 |
SNMP | NET-SNMP 5.7.2 |
[OK] Composer Version: 1.6.5
[FAIL] The session directory (localhost:11211) is not writable.
[FIX] Check the cron job to make sure it is running and using discovery- wrapper.py
./validate.php for development NMS (I see a similar issue on this one as well - only one VRF displays instead of all 11 that I have)
LibreNMS | 1.37-328-ge45aeff |
DB Schema | 252 |
PHP | 7.2.5 |
MySQL | 5.5.56-MariaDB |
RRDTool | 1.4.8 |
[WARN] Your schema (252) is newer than than expected (251). If you just switch to the stable release from the daily release, your database is in between releases and this will be resolved with the next release.
[FAIL] Database: missing column (alerts/note)
[FAIL] Database: extra table (alert_transports)
[FAIL] Database: extra table (alert_transport_groups)
[FAIL] Database: extra table (alert_transport_map)
[FAIL] Database: extra table (transport_group_transport)
[FAIL] We have detected that your database schema may be wrong, please report the following to us on IRC or the community site (Report database schema issues here - LibreNMS Community):
SQL Statements:
ALTER TABLE alerts
ADD note
text NULL AFTER open
DROP TABLE alert_transports
DROP TABLE alert_transport_groups
DROP TABLE alert_transport_map
DROP TABLE transport_group_transport
[WARN] Your install is over 24 hours out of date, last update: Wed, 30 May 2018 19:34:50 +0000
