Lost transceiver rx/tx on Cisco Nexus 3064pq
./discovery.php -h HOSTNAME -d | curl --data-binary @- https://paste.rs/
./poller.php -h HOSTNAME -r -f -d | curl --data-binary @- https://paste.rs/
If you need to post any text longer than a few lines, please use a “pastebin” service, we recommend using https://paste.rs/ or https://paste.sh/
./validate.php
LibreNMS 26.1.0-dev.16+874e45831 (2025-12-17T20:47:18+01:00)
DB Schema 2025_12_05_205509_devices_add_mtu_status (362)
PHP 8.3.28
Python 3.10.12
SNMP 5.9.1
[OK]    Composer Version: 2.9.2[OK]    Dependencies up-to-date.[OK]    Database Connected[OK]    Database Schema is current[OK]    SQL Server meets minimum requirements[OK]    lower_case_table_names is enabled[OK]    MySQL engine is optimal[OK]    Database and column collations are correct[OK]    Database schema correct[OK]    MySQL and PHP time match[OK]    Active pollers found[OK]    Dispatcher Service not detected[OK]    Locks are functional[OK]    Python poller wrapper is polling[OK]    Redis is unavailable[OK]    rrdtool version ok[OK]    Connected to rrdcached
LibreNMS don’t detect or poll rx/tx parameters from some time (don’t know when it happend exacly) in the beggining of december it worked but suddenly I lost all of historical data, and now I don’t even have page tab “dBm” under health tab I downgraded librenms to latest 25 still nothing trier discovery and now I even deleted device and added it from zero. Still dBm not available
When I run lnms device:discovery host -vvv I see
entPhysicalDescr.300061614 = Ethernet1/36 Lane 1 Transceiver Transmit Power Sensor
entPhysicalDescr.300065123 = Ethernet1/38 Lane 1 Transceiver Voltage Sensor
entPhysicalDescr.300065124 = Ethernet1/38 Lane 1 Transceiver Bias Current Sensor
entPhysicalDescr.300065127 = Ethernet1/38 Lane 1 Transceiver Temperature Sensor
entPhysicalDescr.300065133 = Ethernet1/38 Lane 1 Transceiver Receive Power Sensor
entPhysicalDescr.300065134 = Ethernet1/38 Lane 1 Transceiver Transmit Power Sensor
but in ./lnms device:poll I don’t have it.
Can someone help me ? (I found that problem about week ago but don’t know when it appeared)
