Not sure if i’m being stupid, or it’s something else going on here.
I’ve got quite a few Cisco 3850 switch stacks, and they all have Cisco phones attached to them. Many of those phones then have client PCs plugged into them. The MAC address tables in LibreNMS only show the phones MAC addresses on each port, not the PCs as well. I know the switches do contain this data, so I’m curious if this is working 100%, or this is expected behaviour?
php discovery.php -d -m cisco-mac-accounting -h x.x.x.x
LibreNMS Discovery
Version info:
Commit SHA: ad739252a292713b8f932df13cab6247ef19c532
Commit Date: 1510006296
DB Schema: 215
PHP: 5.4.16
MySQL: 5.5.56-MariaDB
RRDTool: 1.4.8
SNMP: NET-SNMP 5.7.2
SQL[SELECT * FROM `devices` WHERE status = 1 AND disabled = 0 AND `hostname` LIKE 'x.x.x.x' ORDER BY device_id DESC]
SQL[SELECT * FROM devices_attribs WHERE `device_id` = '39']
x.x.x.x 39 iosxe SQL[INSERT INTO `device_perf` (`xmt`,`rcv`,`loss`,`min`,`max`,`avg`,`device_id`,`timestamp`) VALUES ('3','3','0','3.06','3.33','3.22','39',NOW())]
SNMP Check response code: 0
SQL[SELECT attrib_value FROM devices_attribs WHERE `device_id` = '39' AND `attrib_type` = 'poll_mib' ]
Modules status: Global+ OS+ Device
#### Load disco module cisco-mac-accounting ####
SNMP[/usr/bin/snmpbulkwalk -v3 -n '' -l 'authPriv' -a 'SHA' -A 'SEKRITS!' -u 'MySNMPThing' -x 'AES' -X 'SEKRITS!' -Oqn -m CISCO-IP-STAT-MIB -M /var/librenms/librenms/mibs:/var/librenms/librenms/mibs/cisco udp:HOSTNAME:161 cipMacSwitchedBytes]
.*.*.*.1.4 No Such Instance currently exists at this OID
SQL[SELECT * FROM `ports` WHERE `device_id` = '39' AND `ifIndex` = '']
>> Runtime for discovery module 'cisco-mac-accounting': 0.0670 seconds with 5320 bytes
#### Unload disco module cisco-mac-accounting ####
SQL[UPDATE `devices` set `last_discovered` =NOW(),`last_discovered_timetaken` ='0.542' WHERE `device_id` = '39']
Discovered in 0.542 seconds
SQL[INSERT INTO `perf_times` (`type`,`doing`,`start`,`duration`,`devices`,`poller`) VALUES ('discover','x.x.x.x','1510046844.0199','0.596','1','my.librenms.server')]
discovery.php x.x.x.x 2017-11-07 09:27:24 - 1 devices discovered in 0.596 secs
SNMP: Get[1/0.06s] Walk [1/0.07s]
MySQL: Cell[2/0.00s] Row[3/0.00s] Rows[4/0.00s] Column[0/0.00s] Update[1/0.00s] Insert[2/0.00s] Delete[0/0.00s]
I can see snmpulkwalk is now running, but failing. The mib path is correct, it’s a consequence of the server running out of space. The path exists, and the MIBs are present. Running the command directly produces the result:
.1.3.6.1.4.1.9.9.84.1.2.1.1.4 No Such Instance currently exists at this OID
More than happy to help debug this, so throw stuff my way and I’ll dig into it.
