Making traffic and CPU graphs scrollable in Libre
I just wanted to know if there’s a way to make it so traffic and cpu graphs are scrollable. For example, if I go into a device onto the “Overview” tab, then I select the “Overall Traffic” window I can select traffic windows of 6/24/48 hours etc. Can I make it so that using my mouse, I can left click on the graph and move the mouse upwards drag the graph out to a larger time frame, or downwards to a smaller time frame or left to slide the time window clockwise and right for anti clock wise:
Any help would be much appreciated.
Kind Regards,
Jimmy
Hi and welcome,
Global Settings -> Web UI -> Graph Settings -> Enable dynamic graphs
should be what you’re searching
Thank you so much! This has worked a treat :smiley:
