Hi@all,
I got an issue with a sensor for an optical interface on a Juniper EX3400.
The threshols don’t really make sense, LibreNMS always alerts “sensor over limit”, so I set the thresholds manually.
So far so good.
But after a few hours/days (random) the values are set to the old senseless ones without having done anything.
Output of ./validate.php:
LibreNMS | 1.50-40-gd31a551
DB Schema | 2019_02_10_220000_add_dates_to_fdb (132)
PHP | 7.2.14
MySQL | 5.5.60-MariaDB
RRDTool | 1.4.8
SNMP | NET-SNMP 5.7.2
[OK] Composer Version: 1.8.5
Output of discovery.php
[root@librenms librenms]# ./discovery.php -h 55
LibreNMS Discovery
xyz-switch2 55 junos
#### Load disco module core ####
>> Runtime for discovery module 'core': 0.0160 seconds with 1168 bytes
>> SNMP: [2/0.07s] MySQL: [4/0.00s] RRD: [0/0.00s]
#### Unload disco module core ####
#### Load disco module os ####
OS: Juniper JunOS (junos)
>> Runtime for discovery module 'os': 0.1550 seconds with 50496 bytes
>> SNMP: [5/0.15s] MySQL: [0/0.00s] RRD: [0/0.00s]
#### Unload disco module os ####
#### Load disco module ports ####
XXXXXXXXXX....XXXXXXXXXXXXXX....................................................
>> Runtime for discovery module 'ports': 0.5440 seconds with 4816 bytes
>> SNMP: [4/0.51s] MySQL: [57/0.03s] RRD: [0/0.00s]
#### Unload disco module ports ####
#### Load disco module ports-stack ####
>> Runtime for discovery module 'ports-stack': 0.2300 seconds with 1768 bytes
>> SNMP: [0/0.00s] MySQL: [1/0.00s] RRD: [0/0.00s]
#### Unload disco module ports-stack ####
#### Load disco module entity-physical ####
Caching OIDs: jnxBoxAnatomy.........
>> Runtime for discovery module 'entity-physical': 1.3090 seconds with 8944 bytes
>> SNMP: [1/1.30s] MySQL: [10/0.00s] RRD: [0/0.00s]
#### Unload disco module entity-physical ####
Module [ entity-state ] disabled on os.
#### Load disco module processors ####
Pre-cache junos: JnxDomCurrentEntry JnxDomCurrentLaneEntry jnxoptIfOTNPMFECCurrentTableJnxoptIfOTNPMFECCurrentEntry
Caching data: processors sensors
>> Runtime for discovery module 'processors': 1.5090 seconds with 200872 bytes
>> SNMP: [13/1.50s] MySQL: [6/0.00s] RRD: [0/0.00s]
#### Unload disco module processors ####
#### Load disco module mempools ####
hrStorage : JUNOS : ..
>> Runtime for discovery module 'mempools': 0.6740 seconds with 93376 bytes
>> SNMP: [9/0.66s] MySQL: [3/0.00s] RRD: [0/0.00s]
#### Unload disco module mempools ####
#### Load disco module cisco-vrf-lite ####
>> Runtime for discovery module 'cisco-vrf-lite': 0.0000 seconds with 2624 bytes
#### Unload disco module cisco-vrf-lite ####
Module [ cisco-mac-accounting ] disabled on os.
Module [ cisco-pw ] disabled on os.
#### Load disco module vrf ####
>> Runtime for discovery module 'vrf': 0.3280 seconds with 5664 bytes
>> SNMP: [4/0.32s] MySQL: [2/0.00s] RRD: [0/0.00s]
#### Unload disco module vrf ####
Module [ cisco-cef ] disabled on os.
Module [ cisco-sla ] disabled on os.
Module [ cisco-cbqos ] disabled on os.
Module [ cisco-otv ] disabled on os.
#### Load disco module ipv4-addresses ####
!!!!!s.
>> Runtime for discovery module 'ipv4-addresses': 0.1240 seconds with 34016 bytes
>> SNMP: [7/0.12s] MySQL: [3/0.00s] RRD: [0/0.00s]
#### Unload disco module ipv4-addresses ####
#### Load disco module ipv6-addresses ####
>> Runtime for discovery module 'ipv6-addresses': 0.1220 seconds with 3192 bytes
>> SNMP: [2/0.12s] MySQL: [1/0.00s] RRD: [0/0.00s]
#### Unload disco module ipv6-addresses ####
#### Load disco module route ####
>> Runtime for discovery module 'route': 0.0000 seconds with 1336 bytes
>> SNMP: [0/0.00s] MySQL: [0/0.00s] RRD: [0/0.00s]
#### Unload disco module route ####
#### Load disco module sensors ####
ENTITY-SENSOR: Caching OIDs: entPhysicalDescr
Airflow:
Current: JunOS ..
Charge:
Dbm: JunOS ....
Fanspeed:
Frequency:
Humidity:
Load:
Power:
Power_consumed:
Power_factor:
Runtime:
Signal:
State: Cur 2, Low: null, Low Warn: null, Warn: null, High: null
.Cur 2, Low: null, Low Warn: null, Warn: null, High: null
.Cur 6, Low: null, Low Warn: null, Warn: null, High: null
.Cur 1, Low: null, Low Warn: null, Warn: null, High: null
Count:
Temperature: JunOS ....
Voltage:
Snr:
Pressure:
Cooling:
Delay:
Quality_factor:
Chromatic_dispersion:
Ber: JunOS
Eer:
Waterflow:
>> Runtime for discovery module 'sensors': 0.5100 seconds with 15704 bytes
>> SNMP: [22/0.42s] MySQL: [106/0.06s] RRD: [0/0.00s]
#### Unload disco module sensors ####
#### Load disco module storage ####
hrStorage : .U.
>> Runtime for discovery module 'storage': 0.4260 seconds with 12616 bytes
>> SNMP: [3/0.42s] MySQL: [7/0.00s] RRD: [0/0.00s]
#### Unload disco module storage ####
#### Load disco module hr-device ####
>> Runtime for discovery module 'hr-device': 0.0640 seconds with 3704 bytes
>> SNMP: [2/0.06s] MySQL: [1/0.00s] RRD: [0/0.00s]
#### Unload disco module hr-device ####
#### Load disco module discovery-protocols ####
CISCO-CDP-MIB:
LLDP-MIB: ...
OSPF Discovery:
>> Runtime for discovery module 'discovery-protocols': 0.2360 seconds with 85896 bytes
>> SNMP: [0/0.00s] MySQL: [19/0.01s] RRD: [0/0.00s]
#### Unload disco module discovery-protocols ####
#### Load disco module arp-table ####
vme.0:
>> Runtime for discovery module 'arp-table': 0.0420 seconds with 3152 bytes
>> SNMP: [0/0.00s] MySQL: [5/0.00s] RRD: [0/0.00s]
#### Unload disco module arp-table ####
Module [ discovery-arp ] disabled on os.
Module [ junose-atm-vp ] disabled on os.
#### Load disco module bgp-peers ####
AS513
>> Runtime for discovery module 'bgp-peers': 0.4010 seconds with 6488 bytes
>> SNMP: [3/0.40s] MySQL: [2/0.00s] RRD: [0/0.00s]
#### Unload disco module bgp-peers ####
#### Load disco module vlans ####
JUNIPER-VLAN-MIB VLANs: ver version1 ....VLAN 1
VLAN 100
VLAN 101
VLAN 102
>> Runtime for discovery module 'vlans': 0.1960 seconds with 10800 bytes
>> SNMP: [6/0.19s] MySQL: [1/0.00s] RRD: [0/0.00s]
#### Unload disco module vlans ####
Module [ vmware-vminfo ] disabled on os.
#### Load disco module libvirt-vminfo ####
>> Runtime for discovery module 'libvirt-vminfo': 0.0000 seconds with 2072 bytes
#### Unload disco module libvirt-vminfo ####
Module [ toner ] disabled on os.
#### Load disco module ucd-diskio ####
>> Runtime for discovery module 'ucd-diskio': 0.0270 seconds with 3160 bytes
>> SNMP: [1/0.03s] MySQL: [1/0.00s] RRD: [0/0.00s]
#### Unload disco module ucd-diskio ####
#### Load disco module applications ####
Applications:
>> Runtime for discovery module 'applications': 0.0190 seconds with 4488 bytes
>> SNMP: [1/0.02s] MySQL: [2/0.00s] RRD: [0/0.00s]
#### Unload disco module applications ####
#### Load disco module services ####
>> Runtime for discovery module 'services': 0.0000 seconds with 296 bytes
#### Unload disco module services ####
#### Load disco module stp ####
STP +++++++++++++++++++++++
>> Runtime for discovery module 'stp': 0.6390 seconds with 7848 bytes
>> SNMP: [4/0.61s] MySQL: [25/0.01s] RRD: [0/0.00s]
#### Unload disco module stp ####
#### Load disco module ntp ####
>> Runtime for discovery module 'ntp': 0.0000 seconds with 232 bytes
#### Unload disco module ntp ####
Module [ loadbalancers ] disabled on os.
Module [ mef ] disabled on os.
#### Load disco module wireless ####
>> Runtime for discovery module 'wireless': 0.0120 seconds with 190928 bytes
#### Unload disco module wireless ####
#### Load disco module fdb-table ####
Q-BRIDGE-MIB:
>> Runtime for discovery module 'fdb-table': 0.1300 seconds with 335648 bytes
>> SNMP: [0/0.00s] MySQL: [49/0.03s] RRD: [0/0.00s]
#### Unload disco module fdb-table ####
Discovered in 8.813 seconds
SNMP [89/6.90s]: Get[37/0.75s] Getnext[1/0.07s] Walk[51/6.08s]
MySQL [328/0.17s]: Cell[135/0.06s] Row[-36/-0.00s] Rows[89/0.06s] Column[2/0.00s] Update[94/0.04s] Insert[38/0.01s] Delete[6/0.00s]
RRD [0/0.00s]: Update[0/0.00s] Create [0/0.00s] Other[0/0.00s]
Output of poller.php:
[root@xyz-librenms librenms]# ./poller.php -h 55
LibreNMS Poller
Starting polling run:
Hostname: xyz-switch2
Device ID: 55
OS: junos
Resolved IP: 172.25.48.21
#### Load poller module core ####
Uptime: 313 days 22 hours 45 minutes 23 seconds
>> Runtime for poller module 'core': 0.0351 seconds with 76264 bytes
>> SNMP: [2/0.03s] MySQL: [0/0.00s] RRD: [1/0.00s]
#### Unload poller module core ####
Module [ unix-agent ] disabled globally.
#### Load poller module os ####
Hardware: Juniper EX3400-24T Switch
Version: 15.1X53-D58.3
Features:
Serial: NV0218050174
>> Runtime for poller module 'os': 0.0875 seconds with 52200 bytes
>> SNMP: [4/0.09s] MySQL: [0/0.00s] RRD: [1/0.00s]
#### Unload poller module os ####
#### Load poller module ipmi ####
>> Runtime for poller module 'ipmi': 0.0014 seconds with 2488 bytes
>> SNMP: [0/0.00s] MySQL: [1/0.00s] RRD: [1/0.00s]
#### Unload poller module ipmi ####
#### Load poller module sensors ####
Checking (snmp) current xe-0/2/3 Tx Current...
Checking (snmp) current xe-0/2/0 Tx Current...
0.03816
0.03684
Checking (snmp) dbm xe-0/2/3 Rx Power...
Checking (snmp) dbm xe-0/2/3 Tx Power...
Checking (snmp) dbm xe-0/2/0 Rx Power...
Checking (snmp) dbm xe-0/2/0 Tx Power...
-8.1
-5.28
-7.83
-3.46
Checking (snmp) state Power Supply 0 @ 0/0/*...
Checking (snmp) state Power Supply 1 @ 0/1/*...
Checking (snmp) state Fan Tray 0 @ 0/0/*...
Checking (snmp) state Fan Tray 1 @ 0/1/*...
Checking (snmp) state Routing Engine 0...
Checking (snmp) state Yellow Alarm...
Checking (snmp) state Red Alarm...
Checking (snmp) state FPC: EX3400-24T @ 0/*/*...
Checking (snmp) state PIC: 24x10/100/1000 Base-T @ 0/0/*...
Checking (snmp) state PIC: 2x40G QSFP @ 0/1/*...
Checking (snmp) state PIC: 4x10G SFP/SFP+ @ 0/2/*...
Checking (snmp) state Routing Engine...
Checking (snmp) state NV0218050174...
6
6
6
6
6
2
2
6
6
6
6
1
1
Checking (snmp) temperature FPC: EX3400-24T @ 0/*/*...
Checking (snmp) temperature Routing Engine 0...
Checking (snmp) temperature xe-0/2/0 Temperature...
Checking (snmp) temperature xe-0/2/3 Temperature...
35
35
26
28
>> Runtime for poller module 'sensors': 0.1939 seconds with 2656 bytes
>> SNMP: [5/0.18s] MySQL: [7/0.01s] RRD: [24/0.00s]
#### Unload poller module sensors ####
#### Load poller module processors ####
8%
8%
>> Runtime for poller module 'processors': 0.0381 seconds with 93056 bytes
>> SNMP: [1/0.03s] MySQL: [3/0.00s] RRD: [3/0.00s]
#### Unload poller module processors ####
#### Load poller module mempools ####
Mempool FPC: EX3400-24T @ 0/*/*: 16%
Mempool Routing Engine 0: 16%
>> Runtime for poller module 'mempools': 0.1431 seconds with 25760 bytes
>> SNMP: [3/0.14s] MySQL: [3/0.00s] RRD: [3/0.00s]
#### Unload poller module mempools ####
#### Load poller module storage ####
Storage /dev/gpt/junos: root file system, mounted on: /.mount: hrstorage
48%
Storage tmpfs, mounted on: /.mount/tmp: hrstorage
0%
Storage tmpfs, mounted on: /.mount/mfs: hrstorage
5%
>> Runtime for poller module 'storage': 0.3577 seconds with 42248 bytes
>> SNMP: [1/0.35s] MySQL: [4/0.00s] RRD: [4/0.00s]
#### Unload poller module storage ####
#### Load poller module netstats ####
ICMP IP IP-FORWARD SNMP TCP UDP
>> Runtime for poller module 'netstats': 0.3140 seconds with 7856 bytes
>> SNMP: [6/0.31s] MySQL: [0/0.00s] RRD: [4/0.00s]
#### Unload poller module netstats ####
#### Load poller module hr-mib ####
Processes Users
>> Runtime for poller module 'hr-mib': 0.0268 seconds with 3024 bytes
>> SNMP: [1/0.03s] MySQL: [0/0.00s] RRD: [3/0.00s]
#### Unload poller module hr-mib ####
#### Load poller module ucd-mib ####
>> Runtime for poller module 'ucd-mib': 0.0571 seconds with 2096 bytes
>> SNMP: [3/0.06s] MySQL: [0/0.00s] RRD: [1/0.00s]
#### Unload poller module ucd-mib ####
#### Load poller module ipSystemStats ####
>> Runtime for poller module 'ipSystemStats': 0.0142 seconds with 1856 bytes
>> SNMP: [1/0.01s] MySQL: [0/0.00s] RRD: [1/0.00s]
#### Unload poller module ipSystemStats ####
#### Load poller module ports ####
Caching Oids: Full ports polling ifDescr ifAdminStatus ifOperStatus ifLastChange ifType ifPhysAddress ifMtu ifInErrors ifOutErrors ifInDiscards ifOutDiscards dot3StatsDuplexStatus
Port me0: me0 (33 / #1711) VLAN = me0bps(7.47 kbps/10.37 kbps)bytes(73.89 kB/102.49 kB)pkts(12.47 pps/4.77 pps)
Port me0.0: me0.0 (34 / #1712) VLAN = me0.0bps(7.46 kbps/10.37 kbps)bytes(73.78 kB/102.49 kB)pkts(12.44 pps/4.77 pps)
Port vme: vme (35 / #1713) VLAN = vmebps(7.1 kbps/10.28 kbps)bytes(70.24 kB/101.65 kB)pkts(11.88 pps/4.73 pps)
Port vme.0: vme.0 (36 / #1714) VLAN = vme.0bps(7.1 kbps/10.28 kbps)bytes(70.24 kB/101.65 kB)pkts(11.88 pps/4.73 pps)
Port ge-0/0/0: ge-0/0/0 (513 / #1715) dot3Duplex VLAN = 1 xyz-ilo-mcp2bps(1.41 kbps/5.97 kbps)bytes(13.94 kB/59.06 kB)pkts(0.95 pps/0.94 pps)
Port ge-0/0/1: ge-0/0/1 (514 / #1716) dot3Duplex VLAN = xyz-ilo-esxi2bps(47 bps/5.08 kbps)bytes(472 B/50.18 kB)pkts(61.73 mpps/49.38 mpps)
Port ge-0/0/2: ge-0/0/2 (515 / #1717) dot3Duplex VLAN = 101 *RESERVIERT*bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/3: ge-0/0/3 (516 / #1718) dot3Duplex VLAN = *RESERVIERT*bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/4: ge-0/0/4 (517 / #1719) dot3Duplex VLAN = *RESERVIERT*bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/5: ge-0/0/5 (518 / #1720) dot3Duplex VLAN = xyz-esxi-mcp2bps(22.26 kbps/12.04 kbps)bytes(220.1 kB/119.04 kB)pkts(4.81 pps/4.73 pps)
Port ge-0/0/6: ge-0/0/6 (519 / #1721) dot3Duplex VLAN = xyz-esxi2bps(23.24 kbps/14.42 kbps)bytes(229.8 kB/142.54 kB)pkts(5.35 pps/5.51 pps)
Port ge-0/0/7: ge-0/0/7 (520 / #1722) dot3Duplex VLAN = *RESERVIERT*bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/8: ge-0/0/8 (521 / #1723) dot3Duplex VLAN = 0 *RESERVIERT*bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/9: ge-0/0/9 (522 / #1724) dot3Duplex VLAN = *RESERVIERT*bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/10: ge-0/0/10 (523 / #1725) dot3Duplex VLAN = xyz-esxi2-vmsbps(9.7 kbps/9.45 kbps)bytes(95.92 kB/93.47 kB)pkts(5.51 pps/4.96 pps)
Port ge-0/0/11: ge-0/0/11 (524 / #1726) dot3Duplex VLAN = *RESERVIERT*bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/12: ge-0/0/12 (525 / #1727) dot3Duplex VLAN = *RESERVIERT*bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/13: ge-0/0/13 (526 / #1728) dot3Duplex VLAN = *RESERVIERT*bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/14: ge-0/0/14 (527 / #1729) dot3Duplex VLAN = *RESERVIERT*bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/15: ge-0/0/15 (528 / #1730) dot3Duplex VLAN = MGMT-Juniper-EX3400bps(12.18 kbps/8.77 kbps)bytes(120.45 kB/86.66 kB)pkts(5.47 pps/4.75 pps)
Port ge-0/0/16: ge-0/0/16 (529 / #1731) dot3Duplex VLAN = Uplink Transport-Netzbps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/17: ge-0/0/17 (530 / #1732) dot3Duplex VLAN = *RESERVIERT*bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/18: ge-0/0/18 (531 / #1733) dot3Duplex VLAN = ge-0/0/18bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/19: ge-0/0/19 (532 / #1734) dot3Duplex VLAN = ge-0/0/19bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/20: ge-0/0/20 (533 / #1735) dot3Duplex VLAN = ge-0/0/20bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/21: ge-0/0/21 (534 / #1736) dot3Duplex VLAN = ge-0/0/21bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/22: ge-0/0/22 (535 / #1737) dot3Duplex VLAN = ge-0/0/22bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/23: ge-0/0/23 (536 / #1738) dot3Duplex VLAN = ge-0/0/23bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/0.0: ge-0/0/0.0 (537 / #1739) dot3Duplex VLAN = ge-0/0/0.0bps(0 bps/118 bps)bytes(0 B/1.16 kB)pkts(0 pps/37.04 mpps)
Port ge-0/0/1.0: ge-0/0/1.0 (538 / #1740) dot3Duplex VLAN = ge-0/0/1.0bps(0 bps/79 bps)bytes(0 B/796 B)pkts(0 pps/24.69 mpps)
Port ge-0/0/2.0: ge-0/0/2.0 (539 / #1741) dot3Duplex VLAN = ge-0/0/2.0bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/3.0: ge-0/0/3.0 (540 / #1742) dot3Duplex VLAN = ge-0/0/3.0bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/4.0: ge-0/0/4.0 (541 / #1743) dot3Duplex VLAN = ge-0/0/4.0bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/5.0: ge-0/0/5.0 (542 / #1744) dot3Duplex VLAN = ge-0/0/5.0bps(0 bps/118 bps)bytes(0 B/1.17 kB)pkts(0 pps/37.04 mpps)
Port ge-0/0/6.0: ge-0/0/6.0 (543 / #1745) dot3Duplex VLAN = ge-0/0/6.0bps(0 bps/156 bps)bytes(0 B/1.54 kB)pkts(0 pps/49.38 mpps)
Port ge-0/0/7.0: ge-0/0/7.0 (544 / #1746) dot3Duplex VLAN = ge-0/0/7.0bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/8.0: ge-0/0/8.0 (545 / #1747) dot3Duplex VLAN = ge-0/0/8.0bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/9.0: ge-0/0/9.0 (546 / #1748) dot3Duplex VLAN = ge-0/0/9.0bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/10.0: ge-0/0/10.0 (547 / #1749) dot3Duplex VLAN = ge-0/0/10.0bps(0 bps/118 bps)bytes(0 B/1.17 kB)pkts(0 pps/37.04 mpps)
Port ge-0/0/11.0: ge-0/0/11.0 (548 / #1750) dot3Duplex VLAN = ge-0/0/11.0bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/12.0: ge-0/0/12.0 (549 / #1751) dot3Duplex VLAN = ge-0/0/12.0bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/13.0: ge-0/0/13.0 (550 / #1752) dot3Duplex VLAN = ge-0/0/13.0bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/14.0: ge-0/0/14.0 (551 / #1753) dot3Duplex VLAN = ge-0/0/14.0bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/15.0: ge-0/0/15.0 (552 / #1754) dot3Duplex VLAN = ge-0/0/15.0bps(85 bps/119 bps)bytes(864 B/1.18 kB)pkts(37.04 mpps/37.04 mpps)
Port ge-0/0/16.0: ge-0/0/16.0 (553 / #1755) dot3Duplex VLAN = ge-0/0/16.0bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/17.0: ge-0/0/17.0 (554 / #1756) dot3Duplex VLAN = ge-0/0/17.0bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/18.0: ge-0/0/18.0 (555 / #1757) dot3Duplex VLAN = ge-0/0/18.0bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/19.0: ge-0/0/19.0 (556 / #1758) dot3Duplex VLAN = ge-0/0/19.0bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/20.0: ge-0/0/20.0 (557 / #1759) dot3Duplex VLAN = ge-0/0/20.0bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/21.0: ge-0/0/21.0 (558 / #1760) dot3Duplex VLAN = ge-0/0/21.0bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/22.0: ge-0/0/22.0 (559 / #1761) dot3Duplex VLAN = ge-0/0/22.0bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port ge-0/0/23.0: ge-0/0/23.0 (560 / #1762) dot3Duplex VLAN = ge-0/0/23.0bps(0 bps/0 bps)bytes(0 B/0 B)pkts(0 pps/0 pps)
Port xe-0/2/0: xe-0/2/0 (561 / #1763) dot3Duplex VLAN = xyz-mcp2bps(14.59 Mbps/12.14 Mbps)bytes(140.93 MB/117.23 MB)pkts(11.38 kpps/10.36 kpps)
Port xe-0/2/3: xe-0/2/3 (562 / #1764) dot3Duplex VLAN = Uplink xyz-switch1bps(12.79 Mbps/14.74 Mbps)bytes(123.54 MB/142.3 MB)pkts(10.59 kpps/11.15 kpps)
Port xe-0/2/0.0: xe-0/2/0.0 (563 / #1765) dot3Duplex VLAN = xe-0/2/0.0bps(57 bps/116 bps)bytes(573 B/1.15 kB)pkts(37.04 mpps/37.04 mpps)
Port xe-0/2/3.0: xe-0/2/3.0 (564 / #1766) dot3Duplex VLAN = xe-0/2/3.0bps(370 bps/262 bps)bytes(3.66 kB/2.59 kB)pkts(0.57 pps/86.42 mpps)
>> Runtime for poller module 'ports': 3.8550 seconds with 38816 bytes
>> SNMP: [15/3.70s] MySQL: [114/0.06s] RRD: [57/0.00s]
#### Unload poller module ports ####
#### Load poller module bgp-peers ####
>> Runtime for poller module 'bgp-peers': 0.0019 seconds with 11456 bytes
#### Unload poller module bgp-peers ####
Module [ junose-atm-vp ] disabled globally.
Module [ toner ] disabled globally.
#### Load poller module ucd-diskio ####
>> Runtime for poller module 'ucd-diskio': 0.0005 seconds with 1824 bytes
#### Unload poller module ucd-diskio ####
Module [ wifi ] disabled globally.
Module [ wireless ] disabled globally.
Module [ ospf ] disabled globally.
Module [ cisco-ipsec-flow-monitor ] disabled globally.
Module [ cisco-remote-access-monitor ] disabled globally.
Module [ cisco-cef ] disabled globally.
Module [ cisco-sla ] disabled globally.
Module [ cisco-mac-accounting ] disabled globally.
Module [ cipsec-tunnels ] disabled globally.
Module [ cisco-ace-loadbalancer ] disabled globally.
Module [ cisco-ace-serverfarms ] disabled globally.
Module [ cisco-asa-firewall ] disabled globally.
Module [ cisco-voice ] disabled globally.
Module [ cisco-cbqos ] disabled globally.
Module [ cisco-otv ] disabled globally.
Module [ cisco-vpdn ] disabled globally.
Module [ nac ] disabled globally.
Module [ netscaler-vsvr ] disabled globally.
Module [ aruba-controller ] disabled globally.
#### Load poller module entity-physical ####
>> Runtime for poller module 'entity-physical': 0.0007 seconds with 1928 bytes
#### Unload poller module entity-physical ####
#### Load poller module entity-state ####
>> Runtime for poller module 'entity-state': 0.0006 seconds with 2224 bytes
#### Unload poller module entity-state ####
#### Load poller module applications ####
>> Runtime for poller module 'applications': 0.0005 seconds with 1472 bytes
#### Unload poller module applications ####
Module [ mib ] disabled globally.
#### Load poller module stp ####
>> Runtime for poller module 'stp': 0.6204 seconds with 8120 bytes
>> SNMP: [4/0.60s] MySQL: [28/0.01s] RRD: [1/0.00s]
#### Unload poller module stp ####
#### Load poller module ntp ####
>> Runtime for poller module 'ntp': 0.0002 seconds with 320 bytes
>> SNMP: [0/0.00s] MySQL: [0/0.00s] RRD: [1/0.00s]
#### Unload poller module ntp ####
Module [ loadbalancers ] disabled globally.
#### Load poller module mef ####
MEF Links:
>> Runtime for poller module 'mef': 0.0007 seconds with 2224 bytes
#### Unload poller module mef ####
#### Load poller module services ####
>> Runtime for poller module 'services': 0.0001 seconds with 0 bytes
#### Unload poller module services ####
Enabling graphs: uptime netstat_icmp netstat_icmp_info netstat_ip_forward netstat_snmp netstat_snmp_pkt hr_processes hr_users
Polled in 6.816 seconds
#### Start Alerts ####
Rule #7 (Sensor over limit - Check Device Health Settings (TEST)): Status: NOCHG
Rule #8 (Sensor under limit - Check Device Health Settings (TEST)): Status: NOCHG
Rule #9 (Service up/down (TEST)): Status: NOCHG
Rule #12 (State Sensor Critical (TEST)): Status: NOCHG
Rule #14 (Device took too long to poll (TEST)): Status: NOCHG
Rule #18 (HPE iLo Server drive degraded/failure (TEST)): Status: NOCHG
Rule #19 (HPE iLo Server Power Supply degraded/failure (TEST)): Status: NOCHG
Rule #20 (HPE iLo Server Fan degraded/failure (TEST)): Status: NOCHG
Rule #21 (HPE iLo Server CPU degraded/failure (TEST)): Status: NOCHG
Rule #22 (HPE iLo Server Memory degraded/failure (TEST)): Status: NOCHG
Rule #23 (Applications OS-Updates, New Updates Available (TEST)): Status: NOCHG
Rule #24 (storage is above the warning level (just servers, no /boot) (TEST)): Status: NOCHG
Rule #25 (Syslog, Auth failure on Device (TEST)): Status: NOCHG
#### End Alerts ####
SNMP [47/5.57s]: Get[23/0.55s] Getnext[0/0.00s] Walk[24/5.02s]
MySQL [190/0.10s]: Cell[51/0.02s] Row[-49/-0.01s] Rows[34/0.03s] Column[1/0.00s] Update[151/0.07s] Insert[2/0.00s] Delete[0/0.00s]
RRD [115/0.01s]: Update[115/0.01s] Create [0/0.00s] Other[0/0.00s]
Does anyone have an idea what is wrong with my LibreNMS?
BR
Jarod
