Feature Request:
Manually defined Default Transport Template ID
Description:
Make it possible in the config file to set a custom Default Transport Template-ID that is different from id = 0.
Reasoning:
If I have deleted Transport Template with the id of 0. I cannot later recreate it. As the id value is incrementally assigned.
A workaround / enhancement IMO is to allow the local LibreNMS admin to manually define the default transport template id.
Implementation suggestion:
Allow the local admin to override the default transport template id.
For backwards combability. The default shall remain id 0. Unless overridden. in the config file.
