My MAP is automatically showing an error. It’s showing devices, but it gets stuck on ‘Loading data’ at the beginning and doesn’t proceed further. If I click on the edit option for MAP, it shows the proper link, but when I view it, it shows ‘Loading data’ at the top. It also shows the devices, but it’s not displaying any details about the links between them or the traffic. How can I solve this? I have also updated LibreNMS
Post the output of validate and also check your browsers developer console to see if any issues are reported there.
please check following output
librenms@inet:~$ ./validate.php
| LibreNMS | 24.9.1-37-ga7167c84d (2024-10-14T02:36:37+05:30) |
| DB Schema | 2024_10_06_002633_ports_vlans_table_add_port_id_index (301) |
| PHP | 8.3.12 |
| Python | 3.10.12 |
| Database | MariaDB 10.6.18-MariaDB-0ubuntu0.22.04.1 |
| RRDTool | 1.7.2 |
| SNMP | 5.9.1 |
[OK] Composer Version: 2.8.1
no isuee detected at browswrs
In your developer console, check for the request to:
maps/custom/MAP_ID/data
What is the status of that request and output?
Hi! May I know if this issue was solve? I’m having the same issue on our librenms map. If this issue was solve can anybody share please at least what to do to fix this. Thank you so much.
@murrant Please check once and update
I believe that this is fixed by the following PR:
The underlying issue appears to be a node that is configured to display an image, but there is no valid image to display. You can fix it immediately by finding the probelm node on your map in the editor and update it to use a valid display option.
Had the same issue after todays auto-update.
Ran daily.sh now and my maps are loading again ![]()
