Morning,
My Network Map is freaking out (shaky and all over the place) since I added Access Points to my list. Is there a way to keep them in LibreNMS but not have them show up in the network map?
Cheers.
Morning,
Cheers.
You can change the map so it is less wobbly, also, you can create a device group and just display that device group.
Check the docs.
Morning, I created a device group, and when looking at the device list it looks good. But the mapping of it still shows everything not just want is in that device group.
