Map Node Width
I’m creating map, and it would be great if you could specify the width of a node, I tried to append or suffix spaces, which worked in the editor until I pressed saved and it trimmed the spaces.
I’d like the ISP node to span across the 3 nodes, so I can make high level map, and then have two smaller nodes above the long ISP node to show each separate link to the ISP upstream
