MariaDB Failure. How to reset librenms password?
I tried logging into Libre yesterday and was met with the “whoops” message. Got onto PUTTY and pulled this for ./validate.php. My first attempt is to upgrade the MariaDB but the documented password for librenms does not work. How can I reset that password? I think once I get that upgraded I can continue to use the WebGUI.
-bash-4.2$ ./daily.sh
Updating Composer packages OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
Caching Mac OUI data OK
-bash-4.2$ ./validate.php
LibreNMS 21.5.1-34-g0489382
DB Schema 2020_12_14_091314_create_port_group_port_table (205)
PHP 7.4.11
Python 3.6.8
MySQL 5.5.65-MariaDB
RRDTool 1.4.8
SNMP NET-SNMP 5.7.2
[OK] Composer Version: 2.1.3
[FAIL] MariaDB version 10.2.2 is the minimum supported version as of March, 202 1.
Update MariaDB to a supported version, 10.5 suggested.
./lnms migrate
[WARN] Global lnms shortcut not installed. lnms command must be run with full p ath
sudo ln -s /opt/librenms/lnms /usr/bin/lnms
[WARN] Bash completion not installed. lnms command tab completion unavailable.
sudo cp /opt/librenms/misc/lnms-completion.bash /etc/bash_completion.d/
lnms user:add --role=admin test
Am I doing something wrong?
[root@Server ~]# su - librenms
Last login: Wed Jun 16 15:44:22 CDT 2021 on tty1
-bash-4.2$ lnms user:add --role=admin test
-bash: lnms: command not found
-bash-4.2$
Do what it suggests to create the lnms link, otherwise you’ll need to run ./lnms
