May i know why in the graph have white color?
Hi all… Current version Librenms was 25.7. Is it normal have white color in the graph?
./discovery.php -h HOSTNAME -d | curl --data-binary @- https://paste.rs/
./poller.php -h HOSTNAME -r -f -d | curl --data-binary @- https://paste.rs/
If you need to post any text longer than a few lines, please use a “pastebin” service, we recommend using https://paste.rs/ or https://paste.sh/
Probably a small issue. FYI, those aren’t white. They are semi-transparent.
They should be the “max” values over the average (the solid green/purple).
Hi Murrant,
So means is it normal or consider will be solved in next version release?
Thanks and appreciate your feedback
No, no one sent a fix.
